Old 08-24-2008, 04:38 PM   #1
dhughins
dhughins's Avatar
got er home barely!
i had the scariest ride of my life but i made it home. this is my 64 swb. the vin decodes to a 3/4 ton 2wd. it has a 67 bed on it for now. back to the scary part. the first red light i came to the brakes locked up and stayed that way for 20-30 miles. i stopped to put some gas in and they were smokin!!!!!!!!! it has drums all the way around and the rears are locking up. supposedly the front is all rebuilt. they look new. i would like to change all to disc but $$$$$$$ is there a cheap way to do this. do any of ya'll have an idea what could be wrong with the brakes that are on there?
dhughins is offline   Reply With Quote
Old 08-24-2008, 04:47 PM   #2
Anthony Fremont
Anthony Fremont's Avatar
Re: got er home barely!
Most likely the rear hose. They can act like check valves holding line pressure even though you let off.
'66 GMC Custom Fenderside LWB
'90 IROC - L98
'97 1200C Sportster
Anthony Fremont is offline   Reply With Quote
Old 08-24-2008, 10:08 PM   #3
MXmaniac
MXmaniac's Avatar
Yeah if the hoses are old they can suck themselves in when you let off the pedal and hold the brakes locked.
Andrew
'69 C-20(292, 4-speed) Retired Daily Driver
'64 C-10(250, 3-speed) Fixerupper
'97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver
If I only wanted two pedals I'd have bought a bicycle.
MXmaniac is offline   Reply With Quote
Old 08-24-2008, 11:38 PM   #4
protrash64
Resistance is Futile
protrash64's Avatar
I have also heard of exhaust heat locking brakes.....check the route in the engine compartment if the other stuff doesnt pan out.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 08-25-2008, 12:11 AM   #5
Slmd92DIME
Slmd92DIME's Avatar
Nice looking start man. I am guessing you decided to trade the 73-87 chevy
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=269019
Petitioning *No Regrets* MD/WV
Slmd92DIME is offline   Reply With Quote
Old 08-25-2008, 12:11 AM   #6
leftcoast66
leftcoast66's Avatar
Glad you made it home... Never fun when that happens. Also going along w/ protrash check under the bed close to exhaust there as well.
leftcoast66 is offline   Reply With Quote
Old 08-25-2008, 12:26 AM   #7
Fred T
Cantankerous Geezer
Fred T's Avatar
First check the emergency brake and cables, if they are connected. Also see if they released after being parked for a while. Usually a rotten hose will leak back after sitting.
If they didn't release, open a bleeder valve on either side. If that releases the brakes, it's probably the hose. But also check the lines for a kink or being flattened.
If they still aren't released, you need to get the drums off. First try backing off the adjustment wheel. It is possible that the adjusting screws were assembled wrong.
If you can't get the drums off, report back for more advice.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
