08-24-2008, 06:07 PM | #1 |
differences in 1/2 ton and 3/4 ton
i just got my 64 home and decoded the vin to be a 3/4 ton what can ya'll tell me about it?
08-25-2008, 12:53 AM | #2 |
Cantankerous Geezer
Re: differences in 1/2 ton and 3/4 ton
Heavier frame and suspension. 8 lug wheels. A full floating differential. The stock differential is a 10 bolt HO52, usually 4.10 or 4.56 gears. And there aren't any better gears to upgrade to, so if you want a highway truck you need to either put in an overdrive tranny or a newer differential.
Fred There is no such thing as too much cam...just not enough engine. |
08-25-2008, 07:52 AM | #3 |
1961 crewcab
I think the rear cabmounts might be a different item (still in the same spot) I think the heavier trucks had vulcanized rubber mounts.
From your pics, it looks to have a 5 or 6 lug wheel. which means that your frame is a 1/2 ton, I wonder if the frame and box are from a 67-72? you can check out the left front frame rail , right about where the #1 spark plug on a v8 is, for the vin # , then you can see if the frame/ cab is switched out. My 60 is a 3/4 ton, but I have changed everything on it, it is now lighter than a 1/2 ton, but I went ahed and still registered it as the 3/4 -it's only an extra $5 tax- rather than try to explain to the dmv what it is now... |
08-25-2008, 05:59 PM | #4 |
the vin on the cab and the number on the frame match. so i'm confused. if it's a 3/4 ton which the vin is #25 why does it have 6 lugs and swb. aren't all 3/4 tons lwb? could the frame have been shortened? does this pic help any?
08-25-2008, 10:02 PM | #5 |
1961 crewcab
they did not make a 3/4 ton swb, so check in between the rear and tranny for welds where they might have shortened the frame.
It is easy enough to un bolt the suspension and replace it with 1/2 ton stuff, so that is what might have happened. does the gvw tag by the left kick panel say 2500 lbs? are you sure that the vin is for a 3/4? |
08-26-2008, 06:33 AM | #6 |
vin is 4C254A104155 when i decoded it on american classic website it said the 25 is for 3/4 ton, 4 is for 1964, a is for atlanta, 104155 is production number
08-26-2008, 07:15 AM | #7 |
I think this frame has been cut down.
"We the willing led by the unknowing, are doing the impossible for the ungrateful. We have done so much for so long with so little, we are now qualified to do anything with nothing." |
08-26-2008, 07:37 AM | #8 |
UCA63
I thought the-c-54a------ stood for longbox
and a 44 would be a shortbox 4=1964 c=single cab pickup 1or2=1/2 or3/4 t or could it be 1/4 or 1/2t 54=lwb,,,,44 for swb A=assy plant 101010 prod # T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
08-26-2008, 11:35 PM | #9 | |
60-66 Nut
08-27-2008, 06:25 AM | #10 |
i think ya'll are right. thanks for the help.
08-27-2008, 08:19 PM | #11 |
ya'll were right here is where the frame was shortened.should i get it boxed in there or scrap the frame all together, or does it look ok? |
08-27-2008, 08:25 PM | #12 |
IS there a plate welded in on the inside of the "c" of the frame where the cut is??
08-27-2008, 08:42 PM | #13 |
i don't think so i'll have to look again tomorrow
08-27-2008, 10:14 PM | #14 |
Cantankerous Geezer
I don't like the looks of that weld on the outside. Can you post pics of the inside of the frame weld?
If I were doing the splice, I would make a doubler that nests inside the frame rail. It's more work than boxing the rail, but it doesn't play havoc with the load distribution like a box does.
08-27-2008, 10:46 PM | #15 |
Resistance is Futile
Just go ahead and Z it!!!!!!!!!!! I think you're going to have a nice collection of road reflectors.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
08-28-2008, 08:06 AM | #16 |
UCA63
I agree ,s/b a step type cut not striaght, looks like po tossed ouy the wrong bed mount,hence the wood blocks.....HMMM
T
