![]() Join Date: Apr 2003
Auto Trans help
I am to the point of finishing up my 72 4X4 project, and i got the motor running, but the trans is another story, i had bought an old parts truck that "supposedly" had a rebuilt 350 trans in it not too much before i bought it, so i figured it would work find, i put a new stall converter in it, and a new filter and fluid, but now when i shift it into drive with the motor running, it will pull the motor down slightly, but won't go forward or backwards. The old fluid i drained out smelled fine, i guess i just don't know what to check first. Is there some easy things to check out first before i give up and take it to the trans shop? (I would hate for it to be something easy and look like an idiot)
thanks David
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
.....I am working on it.....
Re: Auto Trans help
You have the vaccum line hooked up?
There may be foreign material in the valve body somewhere. Linkages are aligned correctly? |
Re: Auto Trans help
well, i figured it out, I guess i'm a dumba$$, as the transfer case was in neutral and, as it doesn't have a shifter on it yet, i didn't check it out
thanks sandking for the attempt to help me David
![]() Join Date: Mar 2003
Re: Auto Trans help
