Old 08-24-2008, 09:46 PM   #1
tobins 52 gmc
tobins 52 gmc
65 mustang gas tank
Has anyone installed a 1965 gas tank in there early 50 gmc or chevy ,and if so do you have any pictures .I talk to a guy here and he says that these tanks work perfect.Thanks Everyone
tobins 52 gmc is offline   Reply With Quote
Old 08-24-2008, 11:20 PM   #2
solidaxel
solidaxel's Avatar
Re: 65 mustang gas tank
I am about to put one out of a 69 Mustang in my 53.
I have removed the crossmember with the hump in it and added one all the way at the back of the chassis, I still need to make a frame to hold the tank to the frame. I havent worked my way back that far on the project, stil working on the steering column and brake arm!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 08-25-2008, 11:10 AM   #3
lazerus
was wondering the same thing i have a spare tank for my wife's 64.5 i was thinking about using
lazerus is offline   Reply With Quote
Old 08-25-2008, 12:50 PM   #4
weldvair@embarqmail.
Check out Tom's trk(57)...www.meyerbrosrods.com
weldvair@embarqmail. is offline   Reply With Quote
Old 08-25-2008, 05:04 PM   #5
floridasteve
floridasteve's Avatar
I have and I hope the picture works. I built the frame around it and it and saved a fortune over buying one from the regular suppliers. Paid $88 for the tank. Just so you know 64-69 is a 16 gallon and the 70-71 is 10 or 10.5 deep and holds 22 gallons.
One day I am going to finish this project!
1949 Chevy 1/2 ton
floridasteve is offline   Reply With Quote
Old 08-25-2008, 05:26 PM   #6
floridasteve
hope this works
1949 Chevy 1/2 ton
Old 08-25-2008, 06:05 PM   #7
solidaxel
solidaxel's Avatar
Thanks that helps.
Where are you going to place your filler opening?
Is there enough room toget it to fit behind the license plate on a roll pan with out too much trouble.
I have my bed at the body shop so I have no way to mock things up, but this step is not far off!
LS 3 4L70E
Old 08-25-2008, 06:08 PM   #8
solidaxel
solidaxel's Avatar
What are you using for the dash fuel gauge?
What ohm sending unit is a Mustang gauge?
LS 3 4L70E
Old 08-25-2008, 06:11 PM   #9
floridasteve
I plan on putting the gas fill in the bed floor. I think the clearance would be an issue for behind the roll pan. THe other thing to consider is the sender. I put a GM sender on the fill tube where the ford one was. I had to bend the arm on the float arm to make it work. I was given this info on the tank from an old school hot rodder. I guess this is a common tank to use based on the flat shape on top and not real deep 8.5 if I remember correctly. The tanks are inexpensive and look good mounted up. Hope this helps someone out there.
1949 Chevy 1/2 ton
Old 08-25-2008, 06:14 PM   #10
floridasteve
Again don't quote me on this but the GM ohm is 0-90 with 0 being empty and the Ford is 7-72 with 72 being empty. So if you don't change the sender the gauge won't go all the way full or empty and it would also be reversed. Hope that makes sense when you read it. That is why I tweaked my GM to fit in the Ford senders location.
1949 Chevy 1/2 ton
Old 08-25-2008, 07:41 PM   #11
BIG CHEVY 3600
BIG CHEVY 3600 LONGBOX
BIG CHEVY 3600's Avatar
Another great fit for the AD gas tank is the Blazer Diesel tank. I just happen to have a never used Blazer tank if anyone is interested. It's been in storage for 15 years and with a little surface rust but in perfect condition.
http://good-times.webshots.com/photo...99708909wTQwcE
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax.
Abraham Lincoln
http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20
BIG CHEVY 3600 is offline   Reply With Quote
Old 08-25-2008, 08:53 PM   #12
tobins 52 gmc
tobins 52 gmc
Thanks guys again ,great info .I will buy my tank torrow along with manny other parts .Another question ,anybody know the corect angle for the dif ,im using a Camaro .Thanks Robert
Old 08-31-2008, 08:56 PM   #13
solidaxel
solidaxel's Avatar
You will have to measure the angle of the transmission first, that will determine what the rear end angle will need to be.
LS 3 4L70E
