Old 08-25-2008, 12:13 AM   #1
rene495
Exclamation 5 inch front drop to much?
I am working on my 72 longbed. I swapping out the front end with new parts. I already have djm comtrol arms that give a 2 inch drop, also coil springs with a 3 inch drop and stock spindles. It will give a 5 inch drop total, Is that to much or should i just us a 2 inch drop spring?
rene495 is offline   Reply With Quote
Old 08-25-2008, 12:19 AM   #2
joe231
joe231's Avatar
Re: 5 inch front drop to much?
I believe 3 inches of drop with springs is gonna cause alignment issues.
you would be better off with 2 inch spindles and 1 inch springs
CHEVY ONLY
Old 08-25-2008, 12:25 AM   #3
rene495
well the control arms give a 2 inch drop. I lready have them. Should i just get a 1 inch spring to go with it?
Old 08-25-2008, 02:48 AM   #4
paisaloco67
If going low is what u want, u will be fine with the 2 inch control arms and
with the 2 inch springs... I do not recomend 3 inch springs.
paisaloco67 is offline   Reply With Quote
Old 08-25-2008, 07:51 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
5 inches of drop is fine,... but using dropped control arms puts the spring pocket very close to the ground. And I think you are going to have alignment issues. A better option is the 3" springs with drop spindles.
Keith
Convert to disc brakes.
Old 08-25-2008, 09:20 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Any combo that uses 3" springs is not going to give you a decent ride. Your much better off with 2" springs if ride quality is of concern.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-26-2008, 06:28 AM   #7
HotRodYJ
HotRodYJ's Avatar
I had 5" drop on the front of my 71 consiting of dropped spindles and 3" springs. No alignmenet issues at all, it aligned perfectly and held alignment just fine. The 3" springs however were very stiff and road very rough. I liked the look of mine that low, just didn't enjoy the ride quality.
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
Old 08-27-2008, 06:20 PM   #8
paintpyro
paintpyro's Avatar
I have heard that the 3 inch drop spring causes some bump steer, so Im using spindles, 3 inch spring, and tubular upper control arms to fix the camber.
70 shortbed stepside
"Schleprock"
350 w/TH400
rallys and BFGs
-We can rebuild it, we have the technology-lower,shinier,faster
paintpyro is offline   Reply With Quote
Old 08-28-2008, 12:16 PM   #9
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
With the lowering A-arms & 3" springs, that is basically the same as having a 5" drop spring
That will give you some alignment problems for sure
If you want to use your lowering A-arms, then a 1" drop spring would be the most I would use with them
And if you want to go lower than that, I would loose the lowering A-arms & get some drop spindles
2" drop springs & some 3" drop spindles would be a much better option IMO
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 08-28-2008, 07:23 PM   #10
rene495
Thanks to all for the advice. i changed my mind and bought stock springs. I have the 3 inch spring still new that im selling for $90. anyone interested send me a message.
