Old 08-25-2008, 06:29 AM   #1
67dragtruck
67dragtruck's Avatar
Astro Van Hydroboost
I've searched and read about the hydroboost setups. I was reading on another couple of sites and evidently the Astro van hydroboosts are popular swaps. Anybody got any info on using them vs. using the 1 ton units. From what I read, the 93 all wheel drive units are the ones to use. Anybody got any input? I really like the look of the smaller hydroboost units compared to a vacuum booster. As far as price, I can get a reman astro van one from OReily for $169 including the core so I thought of doing that instead of the boneyard.
Tom
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc.
My new build thread:
http://67-72chevytrucks.com/vboard/s...17#post2861817
Best pass with the old dragtruck:
5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003
Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup
5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004
67dragtruck is offline   Reply With Quote
Old 08-25-2008, 09:47 AM   #2
pumpkin
pumpkin's Avatar
Re: Astro Van Hydroboost
From what I've been able to find out they are all basically the same. The differences being the mounting, and the size of the accumulator. I have used the 73-87 style on my Blazer and a 94 pu one on my pu. They bothe mounted almost directly, with having to modify only one hole. On the 94 one I turned the mounting plate 180 degrees.
pumpkin is offline   Reply With Quote
Old 08-25-2008, 10:16 AM   #3
FormerMember
Yep. They work really quite well.
FormerMember is offline   Reply With Quote
Old 08-25-2008, 10:34 AM   #4
Custom 68
Custom 68's Avatar
so will you just tee into your current power steering pump for output or will you change that also?
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 08-25-2008, 10:43 AM   #5
FormerMember
Dave
I ran the Astrovan "p" pump, lines and all that. I also used a later model steering box, with the AV's lines. The old box's lines were flared and the new ones are o-ring.
Old 08-25-2008, 02:30 PM   #6
dragginass
dragginass's Avatar
I have seen them installed on several minis. That are really rather easy to install and are super cheap to find. We pulled them from the bone yards and never really had any issues. Ryan that I work with converted his unit to a astro hydro boost on his body drop. He had custom lines made tho that fit alot better. I'll see if I can get him on here to fill in all the tech info.
1971 Chevy C10 LWB Shop Truck
1984 Chevy C30 Dually LWB Tow Pig
1985 Chevy K5 Blazer
dragginass is offline   Reply With Quote
Old 08-25-2008, 06:18 PM   #7
67dragtruck
Cool. Thanks for all the help so far.
Tom
