painting plastic parts
How do you guys paint/dye plastic parts.I ordered new ac bezels for my 67 and they are black. I'd like to have them match the paint. Also, any tips on repairing cracks and painting a steering wheel?
1967 Chevrolet 1/2 ton 4x4 1972 GMC 1/2 ton 4x4 2005 1500 4x4 Suburban 2004 GMC Envoy 4x4 (wife's) |
Resident of Here
Re: painting plastic parts
Steering wheel - http://67-72chevytrucks.com/vboard/s...d.php?t=233643
All I know is that Rustoleum is good for plastic, Krylon is too.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
It's a bit more work but for textured plastic, I hand rub the part with actual sand - get all the "gloss" off and then clean with laquer thinner. I've had nice results with dashes (new and old) and door panels, etc.
Here's a pics of panels... http://67-72chevytrucks.com/vboard/s...d.php?t=281562
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! Last edited by Luvlegs; 08-25-2008 at 01:19 PM. |
I am a Referee of life.
I used brake cleaner on some wheel covers(cheapo Geo so it didn't matter) then aluminum paint.I did the same with a pair of sun visors,7 years and the paint is still OK.Neither would do for show but it made DD's easier to live with.
I did a steering wheel with some epoxy (Filed a good "tooth" on it and just filled,filed and sanded)and cleaned it with steel wool,then sprayed it with brake cleaner.The paint seems to have stayed.I used Krylon but also used a leather cover over the rim to keep from wearing thru the color.I did it about the same time as the visors.Unfortunately I can't remember if I used primer.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 08-25-2008 at 06:02 PM. |
There`s a product called Bulldog and it`s an adhesion promoter for painting plastic and such.I use that stuff on quality parts I want to be sure holds up.My auto paint supplier carries it.If you can`t find it let me know and I`ll get info off a can.
With the cracked steering wheel,just like Deland,I`d cut a bigger bite out of it to fill with JB-Weld or whatever.I`m looking at restoring a 67/67 wheel at the moment.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 08-28-2008 at 08:02 AM. Reason: Bulldog not Bully Dog;) |
Does anyone know how well the Krylon fusion would work?
I think the world needs a drink... ![]() Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd ![]() Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
I always use Bulldog Adhesion Promoter, it works great. I used it on my ATV fenders then basecoat/ clearcoat, it really makes the paint stick. I figure if it will hold up on an ATV, it should work for anything.
I have used NAPA paint stores for many years. They have a plastic prep solvent that is killer good. Its Cross Fire #15250 Wax and grease remover. I use their spray paint they sell made by SEM Products. You can also buy the paint at a number of locations on line. Just get the flexible coating. I've used this stuff on my Vettes, my truck and I just finished the interior of my Carrera. I have NEVER had anything painted with this stuff flake, peel or give any problems at all!
Retired Air Force Veteran
![]() Join Date: Aug 2007
I used Krylon Fusion on the 2 dash vents (heater/defroster) and it worked great.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
#10 | |
Restoration Desperation
it requires no primer and it really bonds well to the plastic surface. I used it on the ABS inner cap on my '73 Airstream Argosy trailer. It has been there almost 2 years and looks brand new. RD |
"THE GREEN GOBLIN"
I just painted my entire dash on my Honda Civic From Light gray to Shadow Blue I used SEM'S COLOR COAT AEROSOLS Formulated to match, restore or change color on most vinyl surfaces, flexible and rigid plastics, carpet and velour. COLOR COAT is fade resistant, flexible and is a permanent coating. COLOR COAT is not a dye. This stuff works good I recomend it! It's between $11.00-$12.80 a can. http://semproducts.com/Catalog.asp?cat=36 you can find it at FinishMasters!
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net Last edited by petey-pablo; 08-28-2008 at 04:00 AM. |
