08-25-2008, 11:19 AM | #1 |
Pics of Installed Big Block Super Comp's
Hey all, I'm just looking for pictures of Hooker Super Comps installed on a big block 2wd. Kind of want both under the hood and from the side looking at the frame rail pictures. Thanks!!
08-25-2008, 01:35 PM | #2 |
Re: Pics of Installed Big Block Super Comp's
Dont super comps hang really low on our trucks? Is your truck lowered?
08-25-2008, 04:34 PM | #3 |
it will be lowered 4/6. i thought the super's tucked better than the regular comp's
08-25-2008, 04:39 PM | #4 |
I tried a set on my old 72 and they hit the motor stand. I ended up with Hedmans. I got the coated and they started to rust about 3 months later. Never driven in rain and was garaged. Cheap.
08-25-2008, 10:40 PM | #5 |
Get a set of regular comps for a chevelle. Thats what I put on mine, its dropped 3/6. Nice and tight, all I had to mod was the crossmember but Im not sure it HAS to be done. I have a floor shifter but if you have a column shift, you will have to mess with the shift linkage a bit. Truck headers hang too low for lowered trucks...
08-26-2008, 06:02 AM | #6 |
what year of chevelle did you use?
08-26-2008, 08:13 PM | #7 |
sorry no pics cause shes in pieces but my super comps on a sb 350 run pretty low the top of the exhaust pipe is about 1" below the bottom of the frame rail.
08-26-2008, 08:38 PM | #8 |
Hooker Competition Black Painted Headers... Part Number: HOK-2455HKR
70-72 Camaro, 70-74 Monte Carlo, 64-74 Chevelle/El Camino/Sprint/Caballero, 71-74 Full Size: 396-502, Tube Size 2" O.D. x 30", Collector Size 3.5" O.D., Collector Length 10", Port Shape: Same As Port, Black High Temp Paint. Hooker Competition Headers offer the best value in the high performance header market. Hooker Competition Headers have a standard finish that features a heat–cured, high–heat–resistant paint. Optionally, the famous Hooker Ceramic Thermal Barrier Coating is available. |
