I have figured it out
All the times i have posted about the truck running rich and then a vibration problem, well i believe i got it fixed. here is what i did.
1. i removed the EGR valve and put the block off plate on. i really did this not expecting much if anything at all. well i believe i did. 2 here is how i set my timing. first i set it (as everyone was saying)with 14* initial. well i did tghis with the advance still hooked to manifold vacuum. i drove it for a tank of gas and the gas milage went to about 15mpg fromabout 12-13 with a BUTT LOAD of spark knock (valve clatter). then i figured i dont have spark knock at wide open throttle so i went to TDC with the vacuum advance disconnected. with it connected i believe it is about 16-17* initial. man this thing runs great and i believe the milage went up some more, will have to update on it. BTW still no spark knock at wide open throttle. BTW i figured i would see what kind of tire spin i had and the thing spun tires all the way through second ( no crap) and i had the TV cable adjusted to loose , it switched to second way to soon, but kept spinning. i have not had that type of oprotunity again yet but i will try the tire spin again. it still feels like the bed is twisting when it changes to second gear though but thats why i spent the 1300.00 bucks on the tranny for.OH yea and the drivability on the freeway, i have to continue to look down at the speedo to make sure i aint getting to carried away with the speed. just thought yall would like to know
2024 Silverado Z71 PPV 1972 Chevy Monte Carlo 2018 Buick Enclave (Wifes) |
| Bookmarks |
