Old 08-25-2008, 10:13 PM   #1
Early 205 Q?
I have a NP205 from a`70,I believe.I cleaner it up on Sunday and was going to remove the front driveshaft and free it from the crossmember.I never paid attention to the fact that it doesn`t have the double cardon joint.What does it take to use a dbl cardon?I have a`71 205 from a 3spd w/a dbl cardon shaft.I haven`t pulled the`71 case so I haven`t looked into it.
Old 08-25-2008, 10:26 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Early 205 Q?
As far as I know, nothing has to change with the NP205 transfer case itself.
I know my 69 K20 with the Rockwell T221 did not have a double cardon joint but when I lifted the truck I had to have one put on the transfer case side of the driveshaft. I didn't have to make any physical change to the transfer case.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-26-2008, 06:04 AM   #3
Re: Early 205 Q?
I had a feeling I was asking you this question and maybe someone else would answer.So the yoke out of the case is the same,I guess.That`s what I was wondering.If I had to break into it I`d want to do it now,before I paint and install and I can roll it around on a bench.I think I`ll leave it be until it asks for service.
Old 08-26-2008, 07:08 AM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: Early 205 Q?
I think they are the same.....1310? joint?
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 08-26-2008, 08:56 AM   #5
FormerMember
Re: Early 205 Q?
The flange for the double cardan will exchange, of course if the spline counts are the same... some early 205's had a 10 spline output and some had 30 splines.
FormerMember is offline   Reply With Quote
Old 08-26-2008, 10:15 AM   #6
cobinder
Everything is work in progress
cobinder's Avatar
Re: Early 205 Q?
2nd what grendel said
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 08-26-2008, 09:51 PM   #7
Re: Early 205 Q?
I`m talking`70 vs`71.I`m thinking they`d be the same.Are you saying there were some 30-splines made back then or are you refering to the later ones around 1980-up?(whenever they all went 30-spline)
Old 08-26-2008, 10:03 PM   #8
FormerMember
Re: Early 205 Q?
I've seen mix and matched t-cases. PO may have swapped a front output into an earlier case, etc.
Old 08-27-2008, 03:23 PM   #9
kwmech
Re: Early 205 Q?
The 205s went to 30 spline front output when GM replaced the yoke with a flange. Of course the 'trick' thing is to really upgrade to a ford 32 spline front output----then you have quite a variety of choices for either flanges or yokes
Old 08-27-2008, 03:27 PM   #10
FormerMember
Re: Early 205 Q?
Kevin, does that mean there isn't a stock 10 spline flange that will fit his case?
If you decide to, I have several Furd 32 spline outputs you can have, with flanges.
I have two Chevy cases with all Furd guts (including the 31 spline input), one going into the K5 project and one already in the C/K30 conversion.
Old 08-27-2008, 03:36 PM   #11
kwmech
Re: Early 205 Q?
Yeah, I'd be interesested some parts--- and on the 10 spline flange, can't say as if I've ever seen one, just the small cv yoke and a couple of other yokes that seem to have gone by the wayside as far as availability goes
Old 08-28-2008, 06:19 AM   #12
Re: Early 205 Q?
I need to look at exactly what I have and see what I`ll need.I`ll look and see after work.
Old 08-28-2008, 07:12 AM   #13
jaros44sr
jaros44sr's Avatar
Re: Early 205 Q?
Wouldn't the small bearing/big bearing, coupler be of importance. As well of the spline count
And the fact of seals not leaking, my underbody sheetmetal is prestine
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 08-28-2008, 07:16 AM   #14
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: Early 205 Q?
There is a good thread right now over on the Pirate board called "some np205 user info for chevy". Its very informative.
http://www.pirate4x4.com/forum/showthread.php?t=653713
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 08-29-2008, 10:44 AM   #15
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Early 205 Q?
Did you ever get this figured out? Don't know if this will help but here is the style that I'm using on my K5's NP205
I don't have a clue what year the NP205 is that I swapped in but if I had to guess I'd be pretty sure it is an early 70's NP205.
Here is a pic of it.
As you can see, when I got the NP205 it didn't have a double cardon joint installed.
Old 08-31-2008, 07:48 AM   #16
Re: Early 205 Q?
No,Mark.I`m just gathering info at the moment.I may get time before winter to swap this in.It`s not my main focus right now.
Old 09-22-2008, 07:57 AM   #17
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
Re: Early 205 Q?
My K-20 does not have the doube cardon joint either. Should The driveline in 4wd be ok for 50mph on dirt roads, no lift? I am guessing it should, just wanted to see what anyone has experienced here.
Thanks in advance!!
Frank
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline   Reply With Quote
Old 09-22-2008, 07:59 AM   #18
FormerMember
Re: Early 205 Q?
Originally Posted by Old Chevy Mech View Post
My K-20 does not have the doube cardon joint either. Should The driveline be ok for 50mph on dirt roads, no lift? I am guessing it should, just wanted to see what anyone has experienced here.
Thanks in advance!!
Frank
As long as it connects the axle to the t-case with out vibrating, your drive line is fine... when you lift these trucks, you need the double cardon to split the operating angles between three joints as it's too much for two/
Old 09-23-2008, 06:42 AM   #19
Old Chevy Mech
Keepin it runnin!
Re: Early 205 Q?
Thanks grendel,
I'll put it back together then. It just struck me as something was wrong with it or it was put on by the P,PO. The 70 Jimmy I had, the 72 K-5 Parts Blazer and my 70 Blazer currently all have the same front driveshaft with the cardon joint. So when I got this 70 K-20 Pickup it stuck out to me me that something was amiss! LOL
Frank
1970 K-5 4X4 Blazer
Old 09-23-2008, 07:59 AM   #20
FormerMember
Re: Early 205 Q?
Thanks grendel,
Frank
You know, I really don't know why GM went through the expense of that joint in their front driver shafts. It's really not an excessive angle.
That said, if it fit in there before and didn't vibrate, you're fine.
Take a look at the picture and you can see that as the axle moves, you have more ujoints to break the angles created by the axle changing position.
Old 09-25-2008, 09:36 PM   #21
Re: Early 205 Q?
I have a TH350/NP205 combo I just pulled from a`70 Blazer and it had a dbl cardon joint.I think new things sometimes get tryed out on only part of the model line-up to test how they work,maybe.I`ve seen this on other areas and other vehicles.Or,since the auto was a new item the new joint design started there.`70 was the second year for auto in Blazers and first for trucks.I never had a`70 automatic truck and can`t say if they would have the double joint.I`d bet they do.I know by`71 all configurations did,even the Blazer 3spd/Dana20.
Old 09-26-2008, 01:13 PM   #22
1969K10
1969K10's Avatar
Re: Early 205 Q?
I'm probably a little late for input, but my T-221 set-up had the double joint at the front axle. When I replaced it with a 205, I got the tranny, X-fer & front d-shaft all together from a '70 (?) blazer. There was not a double joint on the pieces from the blazer. But the d-shaft bolted in w/o any mods.
Oh yeah, the d-shaft from my T-221 was too long to fit after the swap and the d-shaft from the blazer was perfect.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
