Old 08-26-2008, 10:40 AM   #1
56hotrodred
cleaning numerous parts with soda blaster
I am cleaning up as many parts as I can with my new Eastwood Soda Blaster. After completing the grille I noticed some staple-like things on the back of the grille that must be to attach some sort of felt padding - not too sure what else to call it.
I quickly looked in the LMC catalogue to see if they have a replacement part name/number for the thin felt strip that would attach and found none. It was quick look though.
These staple-like attachments are brazed on the back/inside of the grille all around it and I was wondering if I should leave them on and find the padding or if you guys remove them!
By the way the Soda Blaster works great and I expect it is going to save me lots of money in the long run by blasting everything I can before it goes to the body shop.
56hotrodred
56hotrodred is offline   Reply With Quote
Old 08-26-2008, 03:07 PM   #2
solidaxel
solidaxel's Avatar
Re: cleaning numerous parts with soda blaster
How does the soda do on rust and primer?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 08-26-2008, 06:26 PM   #3
56hotrodred
It will remove some surface rust but does very little for anything that is eating into the metal. The unit I have can also be switched to sand to get at the rust. I may have to do some sand blasting on parts of the cab once I remove all the paint and primer and see what I have. The cab is in very good shape and should not need to much sand blasting.
It will remove primer but it takes a little more effort as primer seems to bond better to metal as i guess it is suppose to. In some cases I am removing several layers of paint including some of the original that seems pretty tough.
Eastwood web site has some videos of the small unit that I bought at work.
56hotrodred
Old 08-29-2008, 09:55 AM   #4
56hotrodred
Nobody knows anything about those little clips???
I looked at them again and many are really bent up of missing and they are brazed on.
Should I remove them?
i am also just about done blasting the outside of the cab.
56hotrodred
Old 08-29-2008, 03:16 PM   #5
orgalmeister
I've seen the staples your referring to. I just removed mine. Seemed like too much trouble to find out what they did.
'56 truck (the never ending project)
'06 Z/71 loaded (daily driver)
'07 Mercedes-Benz C-Class (wife's driver)
Gone: 72 SB, 67 CST, 57 BBW, 47 Panel streetrod,
orgalmeister is offline   Reply With Quote
