Old 08-26-2008, 09:02 PM   #1
dhughins
dhughins's Avatar
transmission ?
what does the part look like that connects to the steering column? mine has a green wire. i'm not sure this is how the factory would do it. if you look just above the breather on the driver side of the engine you can see a little green wire. i think this is why it won't go into park.what would that piece be called? or look like? it has a floor shifter, but it was a column shifter from factory.
in the 2nd pic its below the master cylinder, rt by the rear exhaust port hard to see but can't post bigger pictures.
dhughins is offline   Reply With Quote
Old 08-26-2008, 09:36 PM   #2
ValveTubeHead
ValveTubeHead's Avatar
Re: transmission ?
I recognize that as a 3spd manual column shift linkage; sm318 tranny
Matt
'65 LWB Fleetside
'63 SWB Fleetside
ValveTubeHead is offline   Reply With Quote
Old 08-27-2008, 12:09 AM   #3
Captainfab
60-66 Nut
Re: transmission ?
I have no idea where that green wire goes.....three's really no need for it since you have an auto trans instead of a manual. You say you have a floor shifter.....I would look there, it could be out of adjustment. Is it cable operated or mechanical linkage?
Old 08-27-2008, 07:27 AM   #4
Darinc74
Darinc74's Avatar
Re: transmission ?
It won't go into park? Wow. It's amazing me how careless some people can be. What is the other end of the wire tied to?
"We the willing led by the unknowing, are doing the impossible for the ungrateful. We have done so much for so long with so little, we are now qualified to do anything with nothing."
Darinc74 is offline   Reply With Quote
Old 08-27-2008, 08:11 PM   #5
dhughins
dhughins's Avatar
Re: transmission ?
it runs to that black cable that goes off to the left by the header seems to run back to the tranny. i haven't got under it yet to see.
Old 08-27-2008, 08:20 PM   #6
ValveTubeHead
Re: transmission ?
that's the speedometer cable underneath... the shredded boot to the left was for the old clutch pedal rod. Is it a rigged up kick-down for the a/t?
Matt
'65 LWB Fleetside
'63 SWB Fleetside
Old 08-27-2008, 08:29 PM   #7
GMC65Guy
Re: transmission ?
IS it spliced into it?? It looks like its just tied into a knot like to hold it up or something rigged.
GMC65Guy is offline   Reply With Quote
Old 08-27-2008, 08:46 PM   #8
dhughins
dhughins's Avatar
Re: transmission ?
will look again tomorrow. could one of ya'll come watch it while i shift through the gears and tell me what it does. LOL. i live out in the country and don't have carguy neighbors. my wife don't get home from work till after dark.
Old 08-28-2008, 07:30 PM   #9
dhughins
dhughins's Avatar
Re: transmission ?
the green wire is tied through the (linkage?) the metal piece at the end of that cable? any idea? on a floor shifter where would be the part that puts it in park?
Old 08-28-2008, 11:11 PM   #10
GMC65Guy
Re: transmission ?
I have no idea what that wire is there for? Unless that piece of linkage is still connected somewhere to the tranny?
Old 08-29-2008, 09:22 AM   #11
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: transmission ?
so that looks like a 3 speed standard column.
I bet they have that shif lever wired down to engage the neutral safety switch, so you can start the truck.
thats the only reason I can think of why they would want to keep the original disconnected column shift in place.
