Old 08-26-2008, 10:24 PM   #1
bigo181979
Junior Member
bigo181979's Avatar
70 K-5 Blazer front axle swap, what bolts in
Ok i am looking to put a disk brake front axle in my blazer, what goes in with little or no mods???
bigo181979 is offline   Reply With Quote
Old 08-26-2008, 11:09 PM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: 70 K-5 Blazer front axle swap, what bolts in
71-76 Dana 44 or a 77-91 GM 10 bolt...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 08-27-2008, 09:52 AM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
I put a Dana 44 from a 1978 3/4 ton into my 70 K5. The only problem I had was with the brake lines. At the same time I added the 78's power brake master cylinder and porportioning valve. The K5 originally had manual brakes and the drums all around. I ended up making all new front brake hard lines rather than cobble the system together with multiple adapters.
Don't forget you could also put in a Dana 60 but they are of course not usually a cheap purchase. I haven't done that swap yet but there are some people who have that can give you the details of what mods were necessary.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-28-2008, 03:06 PM   #4
bigo181979
Junior Member
bigo181979's Avatar
Ithink I am going to try to stay 6 lug...
