08-27-2008, 03:12 AM | #1 |
In the Forgotten far North.
Vintage air install
Just curious if anyone here has installed a vintage air heater/a.c. system in their trucks and if so how hard was it?
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
08-27-2008, 10:21 AM | #2 |
Insert Witty Text Here
Re: Vintage air install
Someone did. Boatpuller, maybe?
Slonaker |
08-27-2008, 10:43 AM | #3 |
never did one in a C10, but have done them in some hot rods and fords. straight foward, good instructions
1973 C10 "Chain Reaction" Street Trucks cover Feb 2012 2013 Silverado 1964 Cadillac |
08-27-2008, 09:01 PM | #4 |
bingo, slonaker....good memory
it was a good winter project.tore my cab completly down and put dynamat and carpet in at the same time.it's not real difficult.but it's alot easier to tear out everything.which may be a hassle if it's your daily driver.i mainly had some bracket issue's as i swapped the compressor and alt to the other side from there stock location's.they have pretty good instruction's and their tech support is helpful.and the bottom line is it really perform's well.let me know if you need anymore help or have a specific question.glad to help.
" Never look up a dead dogs butt." |
08-29-2008, 03:21 PM | #5 |
Hey Boatpuller how about some pictures of the engine compartment? I'd like to see how things mount up under the hood. Thanks!
My Truck's not leaking its marking its territory! Last edited by 87Bob; 08-29-2008 at 03:23 PM. |
08-29-2008, 08:21 PM | #6 |
i'll snap a couple new one's and post em this weekend Bob.
08-29-2008, 09:52 PM | #7 | |
Frank
Born and proudly residing in a Red State ! |
08-29-2008, 10:19 PM | #8 |
here is mine. I had it installed at the body shop while it was apart after the wreckI was involved in last year. I helped with it some. it really was pretty strait forward, instruction were easy to follow. works & looks great.
75 GMC C-15 short/step factory 454, lowered |
08-29-2008, 10:24 PM | #9 |
Now my next question is.... Can this set up be hooked up to an O.E.M. A.C. compressor on a 1990 suburban with a serpentine belt system where the compressor mounts on the passengers side?
08-29-2008, 10:27 PM | #10 |
go to vintage airs website, or if you call em I bet they can answer your question
08-29-2008, 10:50 PM | #11 |
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
Stepside454, did your truck have factory a/c ? I will be installing a Dropmember on my 77 with fact. a/c and you have to remove the fact. stuff for tire clearence. That set up look's super clean, and would solve my prob.
08-29-2008, 10:53 PM | #12 |
yes mine was a factory ac truck. this is a Sure-Fit Kit from Vintage Air. You have to use a non A/C dash controller with it. John
08-29-2008, 11:05 PM | #13 | |
Here's the full info on it...... http://www.dakotadigital.com/index.c...rod/prd475.htm
08-29-2008, 11:54 PM | #14 |
I have no idea if that could be made to work with it or not
08-30-2008, 01:16 AM | #15 |
this is right from the link above.....
Dakota Digital is proud to release the DCC-2200 Digital Climate Control system designed for Vintage Air Gen-II Air Conditioning systems! Created to interface directly to a Gen-II Air Conditioning system, the DCC-2200 provides convenience of full climate control. Similar to other Dakota Digital instruments, the DCC-2200 offers a full character Vaccum Fluorescent Digital readout for a simple and beautiful approach to updating your A/C system. With a direct plug-in into the Vintage Air Gen-II's wiring harness and the addition of three temperature senders installation is nearly effortless. Backed by a Limited 24-month Warranty against manufacturer defects, Dakota Digital provides the accuracy and performance you've come to expect from an American Made Product!
08-30-2008, 08:49 AM | #16 |
Why did they install the compressor on the left hand side? On the right the lines would be shorter and not cross over the engine.
My Truck's not leaking its marking its territory! |
08-30-2008, 08:54 AM | #17 | |
08-30-2008, 11:22 AM | #18 |
than I would have had to buy new alternater brkts(already had these). Also, the sure fit kit for this truck mounts the compressor on the drivers side, if it were mounted on the pass. side, I would have to toss the lines that come with the system & make all new lines
08-30-2008, 12:31 PM | #19 |
How much is the vintage air kit for our trucks? I cant find prices anywhere...
Any online dealers? Three dealers numbers I called listed in Ohio on vintage's website are out of service. |
08-31-2008, 11:19 AM | #20 |
I paid 1256.00 for the complete sure fit kit, including shipping from Vintage Air. Plus I paid an additional 50.00 for the polished on the compressor.
08-31-2008, 11:44 AM | #21 | |
08-31-2008, 11:51 AM | #22 |
Thanks Boat. Im pleased with it. If you mounted the compressor on the pass. side, the line they give you coming out of the driver side of the radiator support going to the compressor from the condensor coil would have to be modified to go back over to the passenger side. John
75 GMC C-15 short/step factory 454, lowered Last edited by stepside454; 08-31-2008 at 11:54 AM. |
08-31-2008, 11:54 AM | #23 |
i know you live in anchorage.i didn't realize you guy's got that many hot days?their heater and defrost work good,just for your info.
08-31-2008, 11:58 AM | #24 | |
08-31-2008, 12:32 PM | #25 |
how much did the ac kits run on the sqares?
lifes short fabricate as much as you can! |
