1961 Chevy question
Hello,
I'm picking up my first restoration project tomorrow. I'll be flying to Denver to pick it up and then driving her back home to KC. It is a 1961 3/4 ton with 4 speed on the floor and a 327 under the hood. What do you think would be the average crusing speed? I don't want to run her too hard through Kansas, but do you think 65-70 mph would be about right? I'm just trying to figure how long it will take. Thanks in advance and for any other input. Once I get home I'll post some pictures. Joe Last edited by JoeKan; 08-27-2008 at 02:41 PM. |
Re: 1961 Chevy question
Depends on the 4th-gear ratio and rearend gears (probably 3.73, maybe 4.11?)
I'd guess you should plan on more like 55-60mph |
Im only willing to drive about 55-60 in my truck ('65 305V6 3 speed) Thats about as high as it will go unless i feel like winding it up high
![]() Join Date: Oct 2006
My 60 will cruise along at 60
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
I guess I should plan on it being a long day tomorrow.
1961 crewcab
my 65 does best at 50-55.
It was a different time when these were built- radials, interstates were a few years off... |
Cantankerous Geezer
Gears are most likely 4.56, but could be 4.10. Another part of the equation is tire diameter. With 30" tires and 4.56 gears 60 mph will be about 3,000 rpm. I would rum 60, which is what most of the semis are running now. So you won't be getting passed by everybody!
Fred There is no such thing as too much cam...just not enough engine. ![]() |
1962 C-10
Sixty sounds about right. If by chance the axles have been changed out for newer ones, you could 3.73's or higher, you can run 65-70. If they are original, you probably won't have any higher gears than 4.10. 4th gear will be 1 to 1 no matter what. Good luck and have a safe trip! Can't wait to see the pics!
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
You guys were right. I averaged around 55-60 all the way from Denver to KC. It took me 11 1/2 hours. Everything went well though and there were no problems. I'm so glad to be home. The truck is fantastic! I'll post some pictures in a day or two.
