Old 08-27-2008, 03:51 PM   #1
k5hart
k5hart's Avatar
Motor Mount Opinion
I'm in the process of building a 355 for my two wheel drive blazer that will be 350+ HP. It will mainly get driven on the street, and I'll beat on it, but I may also run it at the track from time to time.
I've heard that the stock motor mounts aren't that strong. Is this true? Is it worth switching to '73 and up clamshell mounts or aftermarket ones like performanceonline.com sells?
I would like to put this motor in right the first time but don't want to spend unnecessary money. Any opinions?
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel
Charleston, South Carolina
k5hart is offline   Reply With Quote
Old 08-27-2008, 03:54 PM   #2
lowriden58
lowriden58's Avatar
Re: Motor Mount opinion
im still using the factory style mounts in my 71.. i race it often at the track and abuse it on the street. i also plan on a 200hp NX kit later so i guess ill test them out then too.
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 08-27-2008, 04:10 PM   #3
cdowns
cdowns's Avatar
put a torque strap on the engine drivers side to limit excess movement and you'll be just fine with stock mounts
Old 08-27-2008, 07:59 PM   #4
k5hart
k5hart's Avatar
Excellent idea. I didn't even think of that route. Cheap and simple. Thanks for the answers guys.
Old 08-27-2008, 09:22 PM   #5
Gray Ghost
Gray Ghost's Avatar
Never had a problem with mine...I don't race but I tow a trailer loaded down with lumber regularly.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 08-28-2008, 08:16 AM   #6
Do the later clam shells bolt right in?
Old 08-28-2008, 08:21 AM   #7
lowriden58
lowriden58's Avatar
i think you need new towers for them to be a bolt in piece, or modify your stock towers. also i think if you use the stock towers without modifications the motor will sit higher.
Old 08-28-2008, 02:20 PM   #8
k5hart
k5hart's Avatar
I heard the same thing about the engine sitting higher. I think I'm sticking with my stockers until it gives me a reason to change. Thanks for the input everyone.
