Old 08-27-2008, 06:51 PM   #1
panhandler62
Java Mechanic
panhandler62's Avatar
Suggestions? Economy build
The truck is a 68 C-20 lwb.
I need to finish repairing the frame stiffened area and then I wnat to rebuild the suspension.
What I have:
Stock springs
Truck arms (a bit fugly, but fixable)
Complete front suspension (less sway bar) from an 84 C-20
Set of acceptable (for now) 16" rims & tires.
$2000 to spend
I would like to get a more "car like" stance and good ride/handling and want to be able to enhance things later without tearing it back to frame again.
What is the best use of the money I have to spend?
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 08-27-2008, 08:51 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Suggestions? Economy build
Do you want to keep the C-20 suspension and get a smooth ride too? Your going to need to soften the ride somehow. That means soft shocks and/or soft tires. If you have a high load rated tire it's probably going to have a stiff sidewall so you need to find a tire with a slightly lower profile and less of a load rating.
Gas charged shocks will add to the firmness, so consider large fluid dampened shocks.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-28-2008, 07:17 AM   #3
panhandler62
Java Mechanic
Here is a fast laundry list .. is this a good way to spend $2k?
Spidles $360
Bag, shocks, etc. $1000
Compresser (2 wheel) $400
Adjustable track bar $70
So, that is about $1900, leaving $100 to start the fund for "stuff you need that isn't included."
I can run the rear of schrader valves or (if this works?) run the rear and front each as a unit. I want some adjusability, but it doesn't need to be extream.
Keith
Old 09-04-2008, 07:45 AM   #4
panhandler62
Java Mechanic
A new question arrises as I move along --
While waiting for the money that is going to pay for the things above (it's on the way, but they won't say when.. lol) I am continuing to pick at getting the frame restored and ready.
As you can see in the picture above: I pulled the crossmember that the shocks mount to and I have since removed the snubber and the lower bracket for that crossmember on the right side.
Once I get the same done on the left side I will be ready to get the next crossmember and the frame stiffeners out. Once I get rid of the rust I am going to have a bit less frame left right over the rear end than I want. The compromised area is fairly small and is all in the area that you remove when you install a c-notch so I think that will solve that problem.
I can get some bulk steel and make new frame stiffeners but I note that with notches in place the lower brackets to the center crossmember will be history.
I'm going to go poke arond looking at pictures to get some ideas, but I'll ask anway -- when you notch a frame -- How do you handle shock mounts for the rear and do I need a crossmember here for latteral stiffness?
Keith
Old 09-04-2008, 09:17 AM   #5
LowSmoothCool
Jon@AirRideTech
LowSmoothCool's Avatar
we have a complete coolride kit with a 4 path compressor system that I can get you into complete right around 2,000.00 and it will improve the ride quality dramatically with out comprmising the tow capacity...
LowSmoothCool is offline   Reply With Quote
Old 09-04-2008, 10:01 AM   #6
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
there is no way I would pay $1000 for that bag kit you listed above. Shop around!
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 09-04-2008, 10:12 AM   #7
LowSmoothCool
Jon@AirRideTech
Originally Posted by LowSmoothCool View Post
Forum Guidlines and Rules Updated 06/29/05
VII. No Spamming or Advertising on ANY 67-72Chevytrucks.com forum, regards to any product(s) your pushing, unless you are a paid advertiser, or have had the administrators approval! This guideline is for all Companies and Individuals, using our site to advertise their site of choice or trying to make money off the members! If you are an Individual selling parts for profit (new or used) on a large or semi large scale, this applies to you.
For more info look under Subscribe
as far as i knew we where... LOL there is an ART Banner on top of the page
Old 09-04-2008, 03:38 PM   #8
Liz
Catchy title goes here..
Liz's Avatar
yes there is the issue was no one knew you were associated with air ride. We were not informed of the account being made by anyone from Air Ride, so it appeared as though you were breaking the rules. Your account will be fixed by Josh this evening. We do apologize, but anyone could sign up as a reseller and post the same items, without being associated with the Air Ride account.
Liz
Liz is offline   Reply With Quote
Old 09-04-2008, 03:41 PM   #9
Liz
Liz's Avatar
XII. It is against our policy for someone to post a complaint about a members price on whatever they are selling. If you don't like the price then skip it. Let it drop to the bottom on its own. They (potential buyers) will figure it out, why nobody is jumping on that particular item.
XIII. If you are a long time member, act like one. Lead by example and assist other newer members rather then attacking them. We look upon our veteran members to use this opportunity to teach the newer members the appropriate message board usage.
Old 09-04-2008, 03:43 PM   #10
LowSmoothCool
Jon@AirRideTech
Liz
it's all good i thought jon@airridetech would have been enough LOL its all good thank you very much..
Old 09-04-2008, 09:31 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Jon- We appreciate your understanding as well as your patience in getting your account updated. Just so you know the site went in for it's annual check up this past weekend, and the Admins are still chasing bugs. Your name being pink happened to be one of them.
Thanks for supporting the forum, and just as important thanks for spending time here. Tony used to drop in quite often, but he's too busy for us these days...
Articles-
"Refining Sierra"
