08-27-2008, 10:15 PM | #1 |
Front Brake Rattle - ARGGGGHHHH!!!
First off - it's great to be back around again. Life has been pretty busy, and I have had very little time to snoop around. But finally I am driven back by necessity - a good thing (I guess).
Problem - Loose (rattling) inner brake pad on the driver's side front wheel. Last year I did a fairly complete front brake job replacing everything except the rotors - they still were fine at that time. Recently, a squeak along with a rattle developed on the left side. I checked it and found the brake pads to be loose and badly unevenly worn from front to back. The rotor seemed slightly warped, so I have now replaced the rotors as well as installed new pads. Inner pad is still loose and rattle is still there. The inner pad is riding flush with the rotor (no visible gap), but I can push on the pad "tabs" down and it slides back and forth along the face of the rotor - causing the "tabs" to rattle against the caliper body. So what is going on here? Is the caliper loosening off too much or applying uneven pressure? The retainer clip (inside the caliper piston, holding the inner pad) was not replaced. Could this clip be too loose? Am I missing some hardware? Below are a couple of photos showing the installation and the area where I can move the pad. Any help would be appreciated. BTW - it's great to be "home". |
08-27-2008, 10:43 PM | #2 |
GM ONLY BABY!!!
Re: Front Brake Rattle - ARGGGGHHHH!!!
It looks like that you haven't seated the pads yet. Have you drove it and stomped on the the pedal a few times? Can you hear it rattle when you apply the brakes or something?
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
08-27-2008, 10:57 PM | #3 |
Active Member
What do you mean by rattling? Is it like a vibration or squeeling or just plain sound like they're loose?
I agree with the break in but I wouldn't necessarily stomp on them. From the pics, it looks like your rotors are still fairly new. You can still see the polishing marks. This could cause a vibration on the brakes for some time until they're completely broken in. If they're just loose in there, it could be you are missing some springs that hold them in place. |
08-27-2008, 11:05 PM | #4 |
Built 4 Speed
this might be a dumb question but are you sure they are the right pads? how does the bolts/bolt holes on the spindle itslef look? the rotors straight possibly warped off center??
1969 C/10 Short Box: 496/T-56 in worx. "To Be Old And Wise, First You Must Be Young And Stupid" |
08-27-2008, 11:24 PM | #5 |
I'd check the spring clip inside the piston that holds the pad against it.
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
08-27-2008, 11:52 PM | #6 | ||||||
Thanks for all the quick responses. Here's my answers to your questions...
Thanks guys. Last edited by Zilverado; 08-27-2008 at 11:53 PM. |
08-28-2008, 03:30 AM | #7 |
Green club
I think mine does this too, on the drivers side. When I hit ruts, small bumps in the road I get rattling.
When the brakes are applied it goes away so it's time to pull the wheels. Good luck to you finding the solution
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln Last edited by 67shortie; 08-28-2008 at 01:07 PM. |
08-28-2008, 11:23 AM | #8 |
Never Ending Projects
Do you have the brake pad clip on the inside pad?
This should be clipped to the inner pad and then this clip (with pad attached) should fit tightly within the piston on the caliper. This keeps the pad from rattling around. These spring clips do wear out and loose they "springiness" so you might need to replace them. Good luck.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
08-28-2008, 01:30 PM | #9 | |
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
08-28-2008, 01:39 PM | #10 |
Are there not two sizes of rotor, the hd and the standard. Isn't the HD rotor 1 1/4. Could he have pads for one and a different rotor???
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
08-28-2008, 03:12 PM | #11 | |
Thanks again. |
08-28-2008, 03:14 PM | #12 | |
Hopefully the new pad retainer clips will do the trick... |
08-28-2008, 04:28 PM | #13 |
If the retainer clips are not really rusty, maybe you can bend them out just a bit.
I've never used it, but sometimes when you get new front pads they put some blue goop in a tube. Poke the tube, spread on the back of the pad, makes kinda like a gasket/noise supression type of thing. HTH....good luck.....don t. ..... |
08-28-2008, 04:44 PM | #14 |
Yeah, i guess I could try the "bending" thing, but for less than $3 ea. I think I'll just replace them.
As for the "goop-in-a-tube", I tend to use brake caliper lubricant on the moving parts (bushings, bolts, etc.) but that's about it. I just hope the new retainer clips will do the deed - I'm feeling confident. |
08-28-2008, 04:52 PM | #15 |
MAKE SURE you post up if that was it - it's killling me... just once, I'd like to post "He Shoots, He Scores!"
08-28-2008, 05:04 PM | #16 |
uneven brake pad wear... the first thing that jumps to mind is a frozen caliper pin. check that your caliper pins are both well lubed (copper or silver anti-seeze)
RN U OVR |
08-29-2008, 12:31 AM | #17 |
This can happen too but don't use anti-seeze as I have seen it cause a reaction with the rubber o-ring and cause them to swell. They make disc brake pin lube specifically for this use. It doesn't have the possible reaction with the o-rings.
08-29-2008, 01:05 AM | #18 |
08-29-2008, 01:08 AM | #19 |
If by caliper "pins" you are referring to the 2 long allen-head bolts that hold the callpers in place, yes I lubed these up. I used the purpose made brake lube that comes in a tube. I don't think these are binding.
08-29-2008, 05:50 PM | #20 |
I am a Referee of life.
The Goop mentioned above is anti-rattle compound.It doesn't seem like it would make much difference but it does.I would get some of it and use it when replacing the retainer springs.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
