Seņor Member
Tie rod thread size/pitch?
Does anyone know the tie rod thread size and pitch (one of them is reverse, of course)? I need to pick up a couple of dies to clean up the threads on mine after I cut them down, but I don't have the truck right now to measure them. Parts are 71+, I believe.
Happy to be here
![]() Join Date: Mar 2000
Re: Tie rod thread size/pitch?
Anyone? Would the manufacturers website list that data?
You really shouldn't need a die to clean-up the threads. Just thread a nut on the shaft and after you cut and chamfer the end, back the nut off. This should take care of it. Finding a left hand threaded die, for a one-time use? expensive.
Size ...I would guess 5/8"-18 |
#4 | |
Seņor Member
$15 is not bad, but it is still a "one-time" use thing? Triangle file?
Happy to be here
If your going to need the nuts anyway, that would be the route I would go. When cutting a threaded shaft, I always jamb a double nut on the shaft, then cut off what I don't need. When your done you have two nuts on the good side to chase the threads with.
But you probably already knew that... ![]()
#7 | |
Seņor Member
Happy to be here
Preferably jammed together, cause when they are not....
Surviving, one day at a time!
On my 79 they where 11/16-18. It wasn't a common size I was trying to find heims for it and nobody had them. Ended up sticking with the tie rods.
79 Burb,350,tremic 5 spd, 4 wheel disc, daily driver 74 swb,350,350,driver & future project "There's no such thing as a finished project" |
