Old 08-28-2008, 12:39 AM   #1
Kixwy2
Kixwy2's Avatar
Wiper washer pump troubleshooting?
My wipers work, but some PO pulled the washer fluid assembly and nozzles off and I only just got some replacement nozzles from the pick a part. Went to test the pump and got nothing. No suction, no movement, nothing. It's plugged in and the fuse looks good, as does the wiring. Any ideas?
It'd be really nice to be able to clean bug splatter while driving...
1974 GMC C-10; my new addiction
1998 4 Runner; daily driver
Kixwy2 is offline   Reply With Quote
Old 08-28-2008, 12:47 AM   #2
d10s69c10
Built 4 Speed
d10s69c10's Avatar
Re: Wiper washer pump troubleshooting?
button might be shot. how do all the wires look? might be time to whip out the good old volt meter.
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
Old 08-28-2008, 02:23 AM   #3
CNC
CNC's Avatar
have you bench checked the pump? could be a bad pump I would hook it straight to the battery and see if the pump is working. That is if you have "fire" to the pump
71 Chevy LWB 81 Chevy LWB
I'm not lost.....I'm exploreing!
CNC is offline   Reply With Quote
Old 08-28-2008, 09:59 PM   #4
Kixwy2
Kixwy2's Avatar
Well I hooked up my test cables to the pump and got nothing, so I think the pump might be bad. Unfortunately I can't tell how the pump separates from the motor - it seems to be all connected and the Haynes manual, of course, is no help.
Thoughts?
