Old 08-28-2008, 10:21 AM   #1
Alex Hayley
Polishing kit opinions needed
I need to smooth and polish a few cast aluminum brackets. Has anyone used one of these kits and could provide an opinion.
http://www.northerntool.com/webapp/w...4255_200334255
http://www.northerntool.com/webapp/w...4263_200334263
Alex Hayley is offline   Reply With Quote
Old 08-28-2008, 10:26 AM   #2
lowriden58
lowriden58's Avatar
Re: Polishing kit opinions needed
you can get a decent polishing kit from Sears for 9.99. comes with 3 compounds and a few polish wheels. it works with your electric drill
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 08-28-2008, 10:29 AM   #3
Alex Hayley
Thanks for the quick reply. One requirement for the kit is that there are polishing pads/wheels that allow access to tight corners that would be found on brackets.
I will check on sears.com.
Old 08-28-2008, 10:38 AM   #4
lowriden58
lowriden58's Avatar
I just checked online i didnt see the kit i mentioned. i usually get it at a local Sears. there are different size wheels that come with the kit, and can get in most places. but may not get in very tight corners
Old 08-28-2008, 11:07 AM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Eastwood has a kit that they sell for about $120. It is air-powered and includes the air tool, pads/cones,etc., and compounds. Sherwin-Williams Automotive paint stores sell the same tool for slightly less than $100.
Member Nr. 2770
Old 08-28-2008, 11:36 AM   #6
cdowns
cdowns's Avatar
go to autofair at lowes speedway plenty of vendors for all your polishing needs and the more you buy the better deal they give you
Old 08-28-2008, 04:04 PM   #7
piecesparts
Parts and more parts
piecesparts's Avatar
You can find a fair set of polishing pads and equipment at Harbor freight, but if you want serious stuff start with Eastwoods and then expand out into the Web. I use a lot of 3" and 4" razor buff pads on a die grinder. They ease up the work tremendously on larger flat surfaces. The taper buffs are good for tight corners. Look at the method of polishing, also. Use the dark for cutting the finish (after sanding to a semi smooth finish I usually take mine from a 600 grit down to a 2500 grit before transitioning over to the polishing compunds. The next is to use the green comound to lay out the finish and finalize the color of the metal with the white polish. Never use heavy pressure on the pad, just let it do thework for you.
Practice by trying to polish your fingernails--that is what kind of pressure you want to use.
piecesparts is offline   Reply With Quote
Old 08-28-2008, 05:26 PM   #8
Alex Hayley
piecesparts, that is a great description. Thanks. Is the sanding "from a 600 grit down to a 2500 grit" done by hand or is there a mechanical method of sanding at those grits and also at those grits in tighter corners?
Old 08-28-2008, 06:43 PM   #9
piecesparts
If you use a D&A sander, you tend to get too much gouging in your metal. I use wet-n-dry sandpaper with WD-40 as a lubricant to keep the paper clean. First 600, then 1200 or 1500, and finally 2500 to finish up. This leads to the use of the polishing stuff and the different buffing pads in the process.
