I put a new instrument cluster in my 68 LWB Step side. The original was had just an idiot light cluster so I upgraded to the full gauge package. I have everything hooked up and working correctly except the oil gauge. I have the copper tubing run from the back of the gauge into the engine compartment, I need help identifying where to make the connection to the block. Can I get some help?
GBWatts 68 C10 Stepside LWB Howell, MI |
its all about the +6 inches
Re: Oil Gauge
small bock would be on the back beside the distributor.
big block would be on the side, down low, by the oil filter Inline I have no clue V-6... not even the slightest |
Resident Curmudgeon
![]() Join Date: Dec 1999
Re: Oil Gauge
I6, RH (passenger) side of block, rearward toward bell housing, below pushrod cover. My "guess" is the same place the idiod guage sender came out of regardless of engine (at least this is the case for small block and I6)
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
![]() Join Date: Jan 2007
Re: Oil Gauge
V-8 right behind/right of the dist.
Should look like this (below pic) and should be very close to the firewall. Hope that helps... |
Re: Oil Gauge
(close to the firewall in a 4X4... plenty of room in a 2 wheel drive)
