![]() Join Date: Aug 2008
turn signal trouble
Okay, you guys nailed it last time. Here's another lighting problem(ah the wonders of rust) my brake lights work,taillights work, emergency flashers work,and turn signals in front work. The rears do not work...unless I turn the lights off. Then they work. Any ideas? I have ran new ground wires to new rear light sockets and replaced the bulbs. Any ideas at all? Thanks
Nothing better than an old truck... 76 C-10 Silverado 92 Silverado Z71 |
#2 | |
Active Member
![]() Join Date: Jul 2007
Re: turn signal trouble
That's what I did on mine to resolve a lot of issues with lights in the back and with the guages... I bought the straps at O'reilly's auto parts. |
its all about the +6 inches
do the ground strap thing.... it's cheap.
if that doesn't do the trick... it pretty much has to be in the turn signal switch. |
