PITbut
Anything wrong with this?
You know how sometimes your working on the right side of your truck and you have it jacked up on the frame, is there anything wrong with leaving it sit like that for a day or two??? Just one side of the frame supported and the other side not???
I dont want to bend the frame leaving it like that if its a problem. Basically the right side rear is on the jackstand and the other side is standard height.. Any problems??? |
Resident of Here
Re: Anything wrong with this?
Nah no problems. We had ours like that for a few weeks. No difference in the frame.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
its all about the +6 inches
if it isn't to the extreem it'll be fine. Like parking with one tire on the curb like grandma always does.
#4 | |
PITbut
IM doing the cnotch on it and i figured it couldnt hurt while welding to make sure everything stays as level as i can... |
It's a catastrophic success.
![]() Join Date: Jan 2003
You want to make sure you have your frame well supported and dont have any pressure or in a bind when you do this or your frame will never be the same.
I don't think this is such a good idea when welding/cutting the frame to have any type of "pressure" points" on one side and not the other. But that's just me.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
