08-29-2008, 12:41 AM | #1 |
Need longer brake lines - help!
Well, I finally got around to cutting some stock lower arms so the airbags dont rub (and I sit a lot lower) but now my soft brake lines are too short. They reach, but they are tight and old...so I need new ones, but they need to be longer than stock.
I did some searching and someone mentioned that the 3/4 ton lines are longer but share the same ends. Can anyone verifty this for me? Obviously I am open to any other ideas as well. I am hoping to get everything finished up this weekend and back on the road monday so a custom stainless order isnt really in the cards. Any help would be GREATLY appreciated |
08-29-2008, 12:45 AM | #2 |
its all about the +6 inches
Re: Need longer brake lines - help!
I don't know about the length... but the calipers are the exact same P/N be it a C/10 or a C/20.... so the ends would be the same.
08-29-2008, 12:47 AM | #3 |
Now that is a fast response, thanks a ton.
I didnt mention in my original post, and should have, that the truck has front drum brakes.... and after looking at an old LMC catalog the part #'s for the C10 and C20 are the same, so its pretty easy to figure they are not any loner. Any other off the shelf solutions? Last edited by hollywood68; 08-29-2008 at 01:18 AM. |
08-29-2008, 08:18 AM | #4 |
go to a hose shop and have them custom made is about all i can think of
08-29-2008, 09:39 AM | #5 |
I think you may can use the ones from a K20 (4x4)
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
08-29-2008, 09:39 AM | #6 |
What about 4x4 lines they would be longer?
08-29-2008, 10:28 AM | #7 |
It's a catastrophic success.
Change your steel line, and or relocate where the rubber and steel join to give you more slack
08-29-2008, 10:43 AM | #8 |
thanks for the suggestions, spending some time on Napa's online site trying different models to find one that will work. I wasnt aware they gave the length and end info, great resource...
I could relocate the tab at the chassis but the lines are old and coming apart, so I need new lines as well as longer lines. |
08-29-2008, 11:11 AM | #9 |
Take a look at inline tube for some of their braided brake hose sets.
I am installing a set on another vehicle I own. You can get the braided flex line in various lengths. Get the proper AN to inverted flare or AN to banjo fitting and you are good to go. http://www.inlinetube.com/ |
08-29-2008, 06:35 PM | #10 |
some stainless braided lines would be my preference, if I cant find any off the shelf rubber then that is the route I will go.
I came across a couple that are longer, but the one that I thought would be ideal (almost 3" longer) have 3" of metal fitting at the back of the brake backing plate....not sure that is going to work out very well Still searching... |
08-29-2008, 07:53 PM | #11 |
You can order them from Inline Tube.The guy is gruff when you mention other than stock needs.But,if you know what ends you need and what length they`ll make`em.I had some made after letting him know I knew exactly what I needed and would pay for them regardless.And,the hose(rear) worked perfect.
08-29-2008, 08:20 PM | #12 |
BlahBlahBlah
Are 4x4 lines a little longer? Just tossing this out there.
08-29-2008, 09:26 PM | #13 |
Retired Air Force Veteran
Hollywood, I got my Steel Braided Lines from a Company In California. They came out to around $30.00 each. I sent my rubber lines to assure having the correct ends. If you need them longer, just tell them. Here's the Companies website: http://www.bonacoinc.com/ Ask for Phillip. I was very happy with the final product. Here's a pic of the finished lines:
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors Last edited by myoldchevytruck; 08-29-2008 at 09:27 PM. |
08-30-2008, 12:22 AM | #14 |
I run Crown lines on mine. I think the price was similar to those posted above.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
08-30-2008, 03:15 PM | #15 |
LAIDOUT
Yea, just order the ones for a K20, that is what I did. They are about 4" longer iirc...
08-30-2008, 03:35 PM | #16 |
www.inlinetube.com is who made my hard lines an rubber lines on my truck if you need the rubbers longer just let them know and they can do it
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
08-30-2008, 04:18 PM | #17 |
just got some lines for a 67' Chevy Biscayne and they are 3" longer, but the "fitting" at the backing plate end is about 3"....so have to see if they will work or not.
One of the few vehicles that Napa does not list is the K20, may have to make a phone call or two. |
