Old 11-16-2002, 06:39 AM   #1
jay-dawg
chevelito
jay-dawg's Avatar
Question guage needle removal
I ran a search but couldnt find any info on removing the needle off of the guages. Since I have the dash off of the truck, I might as well get to painting it.
jay
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 11-16-2002, 09:34 AM   #2
Huck
Huck's Avatar
IN most cases the needle can be just pulled forward as it is just kind of crimped onto the shafts. However, if you are going to just paint the needle, you micht consider getting a large piece of paper and cutting one slit to the center - then push it onto the shaft between the needle and the housing. Use a piece of tape to close this slit then you are ready to paint the needle. I kind of prefer this method. Good luck---Huck
Huck is offline   Reply With Quote
Old 11-16-2002, 11:31 AM   #3
Shane
Shane's Avatar
I would be very very careful with this......i tried this about 2-3 weeks ago. The needles came off fine, but the post that runs through the middle of the gage broke and come off too....
These older parts seem to magically "bond" themselves together after 15-20 years.....LOL!
Shane is offline   Reply With Quote
Old 11-16-2002, 01:11 PM   #4
jay-dawg
chevelito
jay-dawg's Avatar
thanks guys,
I was thinking of doing some real carbon fiber for the background (not those sissy sticker stuff) too. I'll take my chances taking the off.
jay
Old 11-18-2002, 08:42 AM   #5
Ed ke6bnl
They do make a special tool that is like a small clamp with a grove in the bottom for the shaft and the screw portion has a very small pin to push pin out the hole in the needle. Ed ke6bnl
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Old 11-18-2002, 09:11 AM   #6
JimKshortstep4x4
Smile
When you remove the needle from the gas gauge, note the position of the needle , because there is no mechanical stop for it like the speedometer. If it doesn't read right when you hook it back up, you may have to pull and reposition the needls.
Jim
Old 11-18-2002, 02:59 PM   #7
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Lightbulb
They do make a special tool. BUT, I have a more economical way, use a fork position under gauge and gently apply pressure, it will push up and pop the needle right off. I have done countless gauges for the new INDIGLO stuff on the newer cars and trucks.
THE KEY, is warm the truck up to operating level, draw a diagram of exactly where each needle pointer is at idle. Then when done with gauges before installing needles. Warm truck up to operating level again. While truck is idling re-install needles in exact position as before. If you do not do this your gauges will never read right again. You will be shootin in the dark. Good luck.
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 11-18-2002, 03:54 PM   #8
jay-dawg
chevelito
jay-dawg's Avatar
gee, I guess I'll have to wait till I get the truck back together huh?
anyway, I was thinking of doing this:
This guy has them on ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...872567212&rd=1
Old 11-18-2002, 04:12 PM   #9
Hooter
My other Love
Hooter's Avatar
Now that's cool!
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
