Old 08-29-2008, 12:23 PM   #1
thachee
Front end "Clunk"
Hi everyone,
I am not new to the threads but haven't posted much. I would like to start by thanking everyone for sharing their knowledge on this forum, it has helped me out numerous times in the past.
I have a 72' C10 and have noticed a clunk coming from the front end lately. It only makes the noise when the brakes are applied or sometimes when turning left at slow speeds. It clunks over small bumps under those two conditions. I have checked out all of the front suspension parts and nothing seems to be loose or out of alignment. The only thing I can think of is the ball joints going bad, but wouldn't this be noticeable when the brakes aren't applied?
Any help would be much appreciated. Thanks
thachee is offline   Reply With Quote
Old 08-29-2008, 12:29 PM   #2
steelhorse
steelhorse's Avatar
Re: Front end "Clunk"
Using a floor jack jack it up as close to the wheel as possible and check for play.You may have the bushings going out in the upper/lower a arm.Or you could have someone drive it real slow and hit the brakes and see if something is moving that shouldnt.
steelhorse is offline   Reply With Quote
Old 08-29-2008, 12:53 PM   #3
eseaton
eseaton's Avatar
watch the u bolts that hold the lower control arm I had mine work loose and it was doing the same thing.
eseaton is offline   Reply With Quote
Old 08-29-2008, 01:54 PM   #4
michael bustamante
michael bustamante's Avatar
check your control arm bushings for sure, also the shock hardware and tie rod ends, but im thinkin the control arm bushings
1967custom
michael bustamante is offline   Reply With Quote
Old 08-29-2008, 02:48 PM   #5
68gmsee
Active Member
68gmsee's Avatar
I definitely would check the supension parts already mentioned but don't overlook the wheel bearings, and/or loose rotor or brake components.
forgot to mention: I once found a loose ball joint on another vehicle by having a 240 pound football playing nephew grab the wheel and shake the h*ll out of it.
68gmsee is offline   Reply With Quote
Old 08-29-2008, 03:27 PM   #6
powell72
powell72's Avatar
This is key, the suspension must be weighted to properly check for play in ball joints.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 08-29-2008, 09:14 PM   #7
dave2953
Dave's not here, man
dave2953's Avatar
I had an issue almost identical to this and it turned out to be the upper control arm. The nuts that hold the shims in place became loose and allowed the arm to move when I hit the brakes/went over bumps.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 08-29-2008, 09:21 PM   #8
Southpa
Southpa's Avatar
Basically check...everything. Years ago I had some funny noises, ie. "clunk" sounds when turning and going over bumps. It turned out to be a loose frame X-member. Those noises can scare the bejeezuz out of you when you start imagining the worst case scenarios.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 08-29-2008, 09:50 PM   #9
thachee
Thanks everyone for the advice. I will definetly check the front over again.
Old 08-29-2008, 09:52 PM   #10
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I had a Dodge with the clunk.I had a shop check the front suspension.They found no problem.I checked.I couldn;t find a problem.It started shimmy(ing) when I would hit some bumps but always did when I crossed the RR tracks on the way home from work.Probably 3 shops and at least 4-5 amatuer mechanics checked the front suspension.I changed tires and wheels.It progressively got worse over a period of about 3 months.Finally one day while I was changing the oil I noticed the problem.The bolts in the steering box had come loose but not out(thank god).Tightened them up and the truck never had another problem suspension wise.I did check the bolts on the steering box at every oil change.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-29-2008, 09:53 PM   #11
cdowns
cdowns's Avatar
also check to see that everything that holds the caliper in place is still present and holding the caliper in place
