08-29-2008, 09:20 PM | #1 |
Adapter For Van Tilt Wiring Needed
I Recently Bought A Van Tilt Column And I Thought I Saw On Here, Or Maybe Another Site, An Adapter That Would Adapt The Flat Wiring Connector On The Van Column To The Circular Connector On The Truck (?) Also, Everywhere I Have Seen That Talks About Adapting The Van Column To The Truck Says To Just Drive The Male Half Of The Intermediate Shaft Intp The Female Half Until It Breaks The Plastic "welds", Making It Adjustable. This Works Fine, But When You Do This, It Makes The Shaft Solid Because You Drive The Two Pieces Together So Far. I Took A Portable Band Saw And Cut The Female Half Of The Intermediate Shaft About In Half. This Way, If I Am Ever In An Accident, The Intermediate Shaft Will Collapse As Intended.
08-29-2008, 10:00 PM | #2 |
Re: Adapter For Van Tilt Wiring Needed
Local GM dealer carries them or maybe one of the board vendors.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
08-29-2008, 11:19 PM | #3 |
its all about the +6 inches
dealer, p/n 1894851
08-30-2008, 12:03 AM | #4 |
Official Site Guitar Shredder
I just did my tilt conversion....And when buying a new turn signal cam and switch it came with the adapter ......was about 30 bucks from napa.....
09-02-2008, 06:10 PM | #5 |
I Took A Portable Band Saw And Cut The Female Half Of The Intermediate Shaft About In Half. This Way, If I Am Ever In An Accident, The Intermediate Shaft Will Collapse As Intended.[/QUOTE]
I meant to say I cut the MALE shaft |
09-03-2008, 01:33 PM | #6 |
Moderator
you can get them from www.truckandcarshop.com
