08-29-2008, 11:54 PM | #1 |
PISS POOR
Air Ride Compressor question
I had been debating which compressor to buy when i thaught of an idea, why not use an old air compressor from a truck a/c system? I know they create plenty of pressure (+200psi i think) but what kind of CFM? Your input would be greatly apreciated!
Slammed 67 long bed with vette suspention build thread http://67-72chevytrucks.com/vboard/s...d.php?t=291149 |
08-30-2008, 12:30 AM | #2 |
3DrDwn--the 'burb not the band
Re: Air Ride Compressor question
been done a hundred times already. the York is the best since it has it's own lubrication. Most modern AC compressors use oil in the freon/R-134 and aren't well suited. A york will fill a 10 gal tank in under a minute and un;ess you're super switch happy you'll never out run it.
The Oasis brand is basically a york connected to a DC motor so it can be mounted anywhere other than on the engine drive. good info here: http://www.kilbyenterprises.com/compressors.htm josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
