Old 08-30-2008, 01:45 AM   #1
dougst29
engine swap
is there a crate engine available that will bolt up to existing transmission and motor mounts for 71 gmc?
dougst29 is offline   Reply With Quote
Old 08-30-2008, 02:19 AM   #2
1969stepside
1969stepside's Avatar
Re: engline swap
a 350 gm crate will fit
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
Old 08-30-2008, 02:19 AM   #3
jef5150
Inline 69
jef5150's Avatar
Re: engline swap
to the Board!
350ci...is the most common
you can put any motor you want in that truck and alot of knowledge here to help you do it!!
jeff
jef5150 is offline   Reply With Quote
Old 08-30-2008, 02:24 AM   #4
sick69
sick69's Avatar
Re: engline swap
This my friend is the great thing about GM!(one of the anyway) They have used the same bell housing (transmission bolt pattern) since the beginning of time. Motor mounts will depend on V8, I6 or V6. The motor mounts can be moved or changed pretty easily though.
If you stay with the size and type you currantly have then you shouldn't have any issues at all.
There are a million companies that make a remanufactured crate engine for the older GM vehicles. Or you can contact your local GM dealer and get a crate engine from the factory.
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 08-30-2008, 09:29 AM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: engline swap
GM and others make tons of different crate engines for small and big block applications.Scoggins-Dickey and pace are two of the largest crate engine dealers for GM but even your local Chevy dealer should be able to hook you up.You can also checkd out some of the car mags and find crate engine copares in them(usually with contact info).
BTW GM now makes a crate stroker at 383 CI
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-30-2008, 09:38 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: engline swap
in order to answer that question acuratly, we need to know what is in your GMC now.
Welcome to the forums.
