Old 08-30-2008, 09:01 AM   #1
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Fuel tank conversion pix
I want to put my tank between the rails. I'm going to do a late model side fill in the bedside. I'd like to see what some of ya'll have done. I called CPP and they want 399 for a tank and about 25 for a sending unit. Is that about right. Is there a certain ohm sending unit I need?
If you have pix post them. (tank and filler neck)
What tank should I run?
Are you happy with the tank that you bought? (Fit, quality and price)
What company has the best deal?
I've already cut out the spare tire crossmember.
Alan's Classic is offline   Reply With Quote
Old 08-30-2008, 09:20 AM   #2
msgross
msgross's Avatar
Re: Fuel tank conversion pix
I suggest aluminum or SS not poly. I tried a poly tank and it just felt like I was installing a plastic "kids toy" type product in the frame....
$399 isn't bad.
nolimit engineering make one for a few companies... Might be something around Atlanta that you can pick up and save shipping.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-30-2008, 11:13 AM   #3
scotts62
One day...
scotts62's Avatar
What is the measurement between your rails? I just bought a new tank and if its close ill send you a link, and ill get a pic up so you can see
Scott
93 crew cab build
Project 62
Old 08-31-2008, 05:16 PM   #4
Alan's Classic
My measurements are 27 1/2 X 16 7/8
Old 08-31-2008, 05:27 PM   #5
Alan's Classic
Here's a pic to help
Old 09-02-2008, 05:49 PM   #6
my67chevytruck
Under Construction
my67chevytruck's Avatar
Nolimit engineering makes good tanks. www.nolimit.net I have used there tanks on my truck and have had no issues. you can also search for member fuel cell guy who is on this site, he custom makes fuel cells as well.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 09-02-2008, 05:54 PM   #7
Alan's Classic
Thanks for the info. I will check them out.
Old 09-02-2008, 07:33 PM   #8
scotts62
One day...
scotts62's Avatar
Here is the one i got. it would be a little tight after you cut and notched some, but its a thought..
Tank
Scott
93 crew cab build
Project 62
Old 09-02-2008, 07:39 PM   #9
Alan's Classic
$399 isn't bad.
I agree not to use poly even thou late model vehicles use them, but they are tucked up and out of the way. Plus aluminum or SS has some bling factor.
Old 09-02-2008, 07:40 PM   #10
Alan's Classic
Tank
That is a good thought. The only thing is I need a side fill. I will do some searching. Thanks
Old 09-02-2008, 08:20 PM   #11
TR65
TR65's Avatar
Hey Alan,
Here is how I did my side fill. Stainless fuel injection tank is from Rick's Hot rod Shop. I had them put in a sender for the stock gage and one for the computer. Tank is ~18 gal and doesn't hang down very far. I fabbed the fuel inlet tubing and used a fuel cell snout for the filler and cap.
Well Alan, the board is so screwed up that it seems impossible for me to post pics.
OK I figured out how to manually resize so here are the pics.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 09-02-2008, 09:44 PM   #12
scotts62
One day...
scotts62's Avatar
Side fill like to the bed side? Where the cap goes it is threaded you could put a 45 on it and run it to wherever you want.
Scott
93 crew cab build
Project 62
Old 09-02-2008, 10:23 PM   #13
Alan's Classic
Is there enough clearance under the bed floor?
Old 09-03-2008, 07:09 AM   #14
tommypic
tommypic's Avatar
I am going with a 82-87 Blazer gas tank . I have found them new for less than a 100$ with the sending unit . If like me and on a budget , but if I had the cash it would be an aluminum tank http://www.speedyautoparts.com/find/CHBLAZER67.html
here is some how to links http://www.67-72chevytrucks.com/vboa...d.php?t=234732
http://www.67-72chevytrucks.com/vboa...d.php?t=212828
http://67-72chevytrucks.com/vboard/s...d.php?t=117123
here is a good all a round FAQ Index thread http://67-72chevytrucks.com/vboard/s...d.php?t=157669
My ZipCode = 29673
2008 Silverado Z71 LTZ Wrecked New Ride SOLD
71-72 Custom A/C Parts Truck < selling parts
67 Chevy ShortStep SOLD
67 GMC SWB Step <-- For Sell
67 Chevy SWB Step <-- working on
2000 Road King <-- SOLD
97 F150 my ride for now
2006 Escape wifes ride
HELP SUPPORT THE BOARD http://67-72chevytrucks.com/vboard/payments.php
Great How To Thread http://67-72chevytrucks.com/vboard/s...d.php?t=157669
Vendor Sites http://67-72chevytrucks.com/links/browselinks.php?c=2
tommypic is offline   Reply With Quote
Old 09-03-2008, 07:26 AM   #15
scotts62
One day...
scotts62's Avatar
should be yea, im raising mine 6 in so i dont know about stock setup.
Scott
93 crew cab build
Project 62
Old 09-03-2008, 08:00 AM   #16
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
When time allows...I plan on fabbing up my own rear tank. I know I could make a custom one for way cheaper than even the Blazer tank.
I used the No-limit one on my customers '67...very nice piece, but pricey for me right now.
I plan to build a tank to utilize the whole space back there, but kinda wrap under the frame too......keep'n it only about 6" max below the frame, mabey less....
My idea:
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 09-04-2008, 09:32 AM   #17
vin63
It's Better With Nitro
vin63's Avatar
Here's the last photo I took when I was mocking up the rear end. My tank is a stainless 20 gal. unit that Fat Fendered Streetrods built for $400.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 09-04-2008, 06:31 PM   #18
Alan's Classic
Thanks guys for the advice, tips and pix. It will be helpful when I make my decision.
Old 09-05-2008, 08:46 PM   #19
TR65
TR65's Avatar
Alan,
Got my pics posted to the original reply above.
Your truck work is looking good!
TR
1965 C10 SWB Fleet
Two owner
Old 09-05-2008, 09:22 PM   #20
Alan's Classic
Originally Posted by TR65 View Post
Alan,
TR
Thanks for the pix and comment.
Old 09-06-2008, 09:16 AM   #21
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Check what I done with my Fuel Cell Bud.........
http://67-72chevytrucks.com/vboard/s...d.php?t=281870
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 09-06-2008, 01:34 PM   #22
Alan's Classic
Sweet!!
Old 09-06-2008, 08:53 PM   #23
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
they mae 30 ohm and 90 ohm senders, I think the cut off year is 64-5? for the last of the 30 ohm senders, and then gm switched to 90 ohm.
Old 09-07-2008, 12:54 PM   #24
Alan's Classic
I'm planning on using one of these fuel doors. I'm leaning toward the square one.
