lowering a c20
What does it take to lower a 1970 c20? I found a smoking deal on a c-20with 87k documented original miles. I want to buy it if i can get it somewhat lowered. It has all coils. I do not want to c-notch. How low would be doable and effecitive? Do they make lowering kits for a c20? Thanks!
Aaron Last edited by Aaron M Rust; 08-30-2008 at 05:59 PM. |
its all about the +6 inches
Re: lowering a c20
the coils are the same size between a 1/2 ton and a 3/4 ton.
So you can run the same drop coils in the C/20 as in the C/10, just don't expect to haul as much. To do that, you'll pretty much need bags. |
