C10 addict
What power steering gearbox are you using?
Just wondering what power steering gearbox everyone is usuing and what changes it took to make it work?
Out of the carpool lane.
Re: What power steering gearbox are you using?
I'm using a quick ratio ps gearbox out of a '77 3+3 cab. It's 3 1/4 turns lock-to-lock and it turns on a dime, but at speed you don't want to sneeze. I'm thinking about going back to reg ps.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... Last edited by Brad; 08-31-2008 at 12:01 PM. |
Using at remanufactured unit, from NAPA, I tried rebuilding my old one, DO NOT TRY THIS, all the ball bearings, and seals, more of a headache than anything, spend the cash on a complete unit, I think mine was like $ 160 or so, I love it, turns 3 1/4 stop to stop, almost to easy,
what year are you putting it on? 67/68 frames (most) need spacers or an adapter to fit a newer PS box.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
C10 addict
I'm putting it on my 67, but it has the raised bolt humps so it should be a direct bolt on, right?
Are all 68-72 PS gearboxes 3 1/4 turns stop to stop |
should bolt in then.... don't know about the stop to stop
AGR variable ratio box. Love it..
![]() Join Date: Dec 2007
I have 71 and used a power steering box off of an 85 1/2 ton, it bolted right on but I had to buy a pitman arm for a 71. The hoses were the problem figuring out at first, I used a power steering pump from a 95 because I switched everything to a serpentine system. I used the factory preasure line from the 85 and ordered a return metal line fitting for the box from LMC, I couldn't find one in the bone yard I was at and the new one wasn't too expensive. The fittings use an O ring seal. The wheels turn so easy you would think the steering linkage was off. It is on my build page below if you want to see what it looks like.
1950 Chevy 3100 Ramp Bed 1-ton http://67-72chevytrucks.com/vboard/s...d.php?t=749386 1965 Chevy Step Side 1971 Chevy Short Wide Bed http://67-72chevytrucks.com/vboard/s...d.php?t=277191 1971 Chevy Chevelle 1972 Chevrolet C-30 1 ton 2002 Winnebego Class A MH Ford E-550 Chassis V-10 2005 Dodge Ram 2500 5.9 Cummins 2008 GMC Denali 2020 Jeep Wrangler Unlimited Rubicon Last edited by awhite4557; 08-31-2008 at 02:59 PM. |
![]() Join Date: Aug 2004
My box is from an 87. I swapped the valve/fitting in the 68 pump for the later type so I could use the newer style o-ring hose.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 08-31-2008 at 02:53 PM. |
C10 addict
How did you guys connect the gearbox to the steering column? I was told that the splines are different between the 67-72 gearbox and the 73-87 gearbox
I got the rag joint with the new box, the D-shape shaft at the end of the column is the same.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
C10 addict
What about the pitman arm splines, are they the same?
#13 |
![]() Join Date: Feb 2001
I bought a "REDHEAD" 69-72 Remanufactured Power Steering Gear - 2X4 Quick Ratio from WES.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#14 |
The box from the 85 bolted right up to my 71 rag joint, everything worked just like the 71 box. The pitman arm splines were the same as well.
1950 Chevy 3100 Ramp Bed 1-ton http://67-72chevytrucks.com/vboard/s...d.php?t=749386 1965 Chevy Step Side 1971 Chevy Short Wide Bed http://67-72chevytrucks.com/vboard/s...d.php?t=277191 1971 Chevy Chevelle 1972 Chevrolet C-30 1 ton 2002 Winnebego Class A MH Ford E-550 Chassis V-10 2005 Dodge Ram 2500 5.9 Cummins 2008 GMC Denali 2020 Jeep Wrangler Unlimited Rubicon |
#15 |
Got a variable ratio box out of a junkyard '77 as well. It's not twitchy on the highway for me though.
#16 |
Truck and auto performance nut
What year was the 1st year for the variable ratio units?
'77?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#17 |
I tried 3 gearboxes in the last year for my 67. I replaced the first leaking one with a stock one I was given... it leaked as well.
Then I bought a "quick ratio" gearbox and had it on until a few weeks ago. It's fine for around town but if your going freeway speeds it's pretty twitchy. I just put on a "variable ratio" gear box for a '76 PU. It's a direct replacement, no problem with fittings. Got a rebuilt from NAPA for $130. I like it the best.... it still has that half inch of freeplay but I'm not afraid of something drastic happening when having to make a quick lane change on the freeway and you don't have to turn the wheel as much in a parking lot. Kind of like the 3 bear story.... not too slow, not too fast, it's just right. Well at least it is for a direct replacement (not changing other parts). Last edited by Mondo; 09-10-2008 at 07:32 PM. |
#18 |
so the v/r box for a '76 1/2 ton truck has the flange style fittings, and not the o-ring style? If that's the case...it sounds what I need to swap to. I had a o-ring style system and went to a stock '72 box when switching everything back to flange.
Now I miss the v/r box that was in there. ![]()
#19 |
Can you only direct fit truck steering boxes? I wondered about a box from something like a Monte Carlo.
#20 |
Most of the car stuff bolts to the inside of the frame, trucks on the outside.
#21 | ||||
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
The years are 69-76 for the 4 1/2 turns, 77-87 for the 3 1/4s. Our stearing gears that we get from Redhead are 3 1/4 turns lock to lock and have the larger input shaft that the 69-76 trucks have. We have them custom made for this aplication. If you do not dent the frame befor you install the integral steering gear (no matter what year you use) it will be twitchy. This is because when mounted to a 67 and some early 68s, raised pattern for the bolts is not enough. So when you shim it out, or just try to force the boltsyou can not get the gear where it is supposed to be. It will be 1/4" too far to the left, causing the gear to run off center. This is where the twitchyness comes from. Dent the frame to allow for the extra large size of the gear (like the factory did from late 68 to 87) and you allow the gear to run in center. Center is where the gear has just enough play in it so that if you twitch your hand slightly, your gear doesn't turn. Hope this helps. WES You will also need to buy another rag joint assembly, because the manual stearing gear has a different size input shaft.
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys Last edited by Classic Heartbeat; 09-03-2008 at 11:56 AM. |
#22 |
Texas Big Wig
I put the power steering box off of my black truck on my 67 project (I believe the box to be 77 & later) And I had to space it out with 2 thick washers on each bolt & had to trim my core support mount just a lil
Not that big a deal, just know it wont JUST bolt on ![]() |
#23 | |
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
#24 | |
C10 addict
#25 | |
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
