Old 08-31-2008, 12:27 PM   #1
ojh
gas gage woes
i rewired a '52 panel wagon and it has repro gages, the gas gage won't work. The sending unit in the tank is a modern sender, is the new resistor compatable with the early gage If not is there a fix. Appreciate any help, thanks oj
ojh is offline   Reply With Quote
Old 08-31-2008, 05:21 PM   #2
Gene Sharp
Re: gas gage woes
Ok you are dealing with two problems
One the early guage is 6 volt
you need a resistor in the positive lwire to guage to drop
your voltage from 12 volts
Second is check out the ohm reading on the sender
most modern guages have a different ohm Value
so what I did (on 53 Chevy pickup with blazer gas tank)
I was putting in a new tank so found a flat place on top of tank and took a hole saw and drilled a hole the size for the 53 guage and installed it
I them used the origional Blazer pickup tube to get gas and hooked guage wire
to 53 sender and it works
Gene Sharp
Gene Sharp is offline   Reply With Quote
Old 09-01-2008, 07:03 AM   #3
ojh
Re: gas gage woes
Thanks Gene, never even thought about the 12v to 6v thing. Will ponder on this a bit.
