Old 09-01-2008, 10:49 AM   #1
1984Silverado4x4
Groaning Clutch
When I drive my truck and its had a chance to warm up every time I push in or let out the clutch pedal it groans. This has been happening since I got the truck and even after I put a new Clutch and pressure plate in it and greased everything up it still does it. I've trying greasing a couple things on the linkage but it still groans.
Does anyone else have this problem or have any ideas what it could be.
Its no disgrace being poor. Its just inconvenient.
1984Silverado4x4 is offline   Reply With Quote
Old 09-01-2008, 11:03 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Groaning Clutch
hey there i had for a while a 76 that had been sitting for a while before i got it and it had been an old farm truck. anyway my clutch did the same thing and it was actually the return spring under the dash that was doing it... when i swapped out the cab for a newer one, i wound up using a different spring that got rid of the problem
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 09-01-2008, 11:36 AM   #3
1984Silverado4x4
Re: Groaning Clutch
Nope its not the spring doing it
Old 09-01-2008, 02:05 PM   #4
GMBowtie79
Surviving, one day at a time!
GMBowtie79's Avatar
Re: Groaning Clutch
I'd start looking at the parts you didn't change. If the noise is coming from inside the cab I'd start with the clutch petal bushings, neutral safety switch, linkage boots, the linkage connection at the petal, also try tightening the two bolts that attach the cluch petal together( petal arm is two pieces). If it,s coming from outside throw out fork, throw out fork boot, lube the bell crank and ball, and all other linkage points.
79 Burb,350,tremic 5 spd, 4 wheel disc, daily driver
74 swb,350,350,driver & future project
"There's no such thing as a finished project"
GMBowtie79 is offline   Reply With Quote
Old 09-03-2008, 05:18 PM   #5
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: Groaning Clutch
Sounds like a bad throwout bearing...
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 09-03-2008, 07:08 PM   #6
1984Silverado4x4
Re: Groaning Clutch
Has a brand new throwout bearing in it. Could be I didnt do a good job greasing it though. I cant hear any groaning if I lay under the truck while someone pumps the clutch pedal.
Old 09-03-2008, 08:36 PM   #7
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: Groaning Clutch
Find every single metal/metal contact point in the clutch linkage, including everything under & behind the dash and lube them. I've got one spot under the dash that needs a squirt of WD40 every 4-5 months, else it groans just like you describe.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
