Old 09-01-2008, 03:48 PM   #1
allen123
It'll buff out
allen123's Avatar
Help with heating the coils
I think im going to lower my rear end today by heating the coils.
And I just have a few questions.
Do i just heat up the whole coil or just one point on the spring?
How much do i need to heat it up? Until its red?
And what will happen it its uneven?
And just put in any tips you have that i didn't ask about.
Sorry I don't know much.
1972 Chevy c10 swb
2008 CBR600RR Grafitti edition
My Build
Cody Allen
allen123 is offline   Reply With Quote
Old 09-01-2008, 04:16 PM   #2
ca180
tryin to get laid
Re: Help with heating the coils
Sorry, my only advice is don't do it
ca180 is offline   Reply With Quote
Old 09-01-2008, 04:21 PM   #3
cdowns
cdowns's Avatar
dumb thing to do
Old 09-01-2008, 04:23 PM   #4
LONGHAIR
The best "help" there is........."Don't do it"
LONGHAIR is offline   Reply With Quote
Old 09-01-2008, 04:57 PM   #5
Shane
Shane's Avatar
Your safety as well as every other person on the roads are worth the $100 a set of drop springs cost.
Save your money and do it right.
Shane is offline   Reply With Quote
Old 09-01-2008, 06:41 PM   #6
spr85gmc
spr85gmc's Avatar
drop spring $100
cost of repairs when u break a coil when you thought you were being smart and save money aloooooooooot more do it right or dont do it at all too risky and nt worth the trouble.
spr85gmc is offline   Reply With Quote
Old 09-01-2008, 06:51 PM   #7
ont_guy_38
ont_guy_38's Avatar
we did that to a 72 once all i got to say is listen to the guys above!!!!!!!!!!!!!!!!!
ont_guy_38 is offline   Reply With Quote
Old 09-01-2008, 07:30 PM   #8
71swb4x4
71swb4x4's Avatar
Another vote for don't do it. My old Jimmy had heated coils when I bought it, they rode horribly. They were one of the first things to get replaced.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-01-2008, 09:05 PM   #9
allen123
It'll buff out
allen123's Avatar
Ok haha thanks i guess i will just save up the money. Also i heard of putting s10 or monte carlo springs will lower it how is the ride quality in those?
1972 Chevy c10 swb
My Build
Cody Allen
Old 09-01-2008, 09:06 PM   #10
hdflstf
hdflstf's Avatar
Spring steel doesn't take kindly to being heated to yield. They will break sooner or later with the loss of the physical properties in the area that was heated. Don't do it.
hdflstf is offline   Reply With Quote
Old 09-01-2008, 10:58 PM   #11
joe231
joe231's Avatar
here is my thread where i used jeep wrangler coils
http://67-72chevytrucks.com/vboard/s...d.php?t=292466
do a search of jeep coils....should be lots of info
CHEVY ONLY
Old 09-02-2008, 09:55 AM   #12
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Dang, I cant stand when all these guys bag on heating coils
Heres how you do it... MAY NOT be the BEST way, but does work & I havent had ANY problems from doing it
You start at the bottom & start heating it up (till its orange & starting to twist) then you start moving up the coil till you have reached the desired amount of drop
I like to park mine one some cement & have a buddy keep a tape measure ran from the ground to the fender well & keep track of how many inches of drop you've done
I have done up to 6" but the ride sucks, so 4" or maybe 5" is about the most I would do
Oh, & when you lower the first side it will be a lil lower than when you lower the second side (because its not level at that point)
Hope you get it done & have no problems just like me & hundreds of other people who have done it for the past 40 years
Now, I will go out saying one last thing here
Im not saying this is the best thing to do or anything you should do, just another option in the lowering world & if you want to be low & ride good & not worry about springs breaking, then bag your truck
Its not much different in price from drop springs & you dont have to have a tank & compressor, just a lil bit of air line & a couple schrader valve will do the job just fine
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 09-02-2008, 10:41 AM   #13
thelonerife
thelonerife's Avatar
The only reason I would heat a spring is to get an idea of how much drop I wanted to install. (To order my springs). If you do a wanted ad in the parts section for some, somebody just might hook you up. i have some 5'' rear and 2'' front that I'm still not sure I'm going to use. I want to get my wheels/tires first. But somebody I'm sure has some laying around. Don't forget if you go real low you may need to relocate shocks and might need to change your panhard bar. Do it safe or don't do it.
thelonerife is offline   Reply With Quote
Old 09-02-2008, 03:54 PM   #14
joe231
joe231's Avatar
i have heard of people using jack stands under the frame to "land" the truck at the proper height, then let them cool and remove the stands....i have never done it, just heard some talk of it
CHEVY ONLY
Old 09-02-2008, 05:05 PM   #15
el curioso
el curioso's Avatar
lowering blocks
1969 Chevy C-10 350/700r4
el curioso is offline   Reply With Quote
Old 09-02-2008, 05:05 PM   #16
allen123
It'll buff out
allen123's Avatar
Are they cheaper than springs?
1972 Chevy c10 swb
My Build
Cody Allen
Old 09-02-2008, 07:35 PM   #17
LONGHAIR
You can only lower about 2" with blocks. You start running into another safety issue with more than that.
Yes, I have done the jackstand thing....way back in the day. Part of the reason I wouldn't reccommend doing it. It does not ride well. Those coils are essentially "stacked" like "coil bound" and that leaves a lot less spring to carry the load...it's a lot stiffer.
Old 09-03-2008, 12:35 AM   #18
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
You can get some Slam Specialties bags from Suicide Doors, for $75 a piece
And you can get some drop springs from CPP for $95 a pair
So its about $55 bucks more to go with bags
But the cool thing about the bags is, if you ever hook onto a trailer you can just air it up more to keep it level & if you ever decide to bag the front, the rear is already done
Its what I would do if I was going to buy something
IMO, just heat em, see if you like the height & then buy some bags & put under it
Sinister
Killer
Old 09-03-2008, 08:40 AM   #19
N2TRUX
Happy to be here
N2TRUX's Avatar
Sorry, but just because you have done it doesn't mean it's something that should be recommended. Yes you can heat your coils and get it low cheaply. The possibility of the spring actually breaking is low, but the probability that it will continue to sag is guaranteed.
If you want to cheap out now, be forewarned that your truck will ride like crap and progressively get worse. Anything more than a 3" drop by spring regardless of how it accomplished will net a poor ride. Heating the springs is the fastest way there.
You can replace the springs now, or heat them and replace them later.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-03-2008, 04:05 PM   #20
el curioso
el curioso's Avatar
Lowering blocks FAQ
Old 09-03-2008, 04:34 PM   #21
Shane
Shane's Avatar
Not the "best" way to do things, but I have a set of rear Malibu / Chevelle springs that I'm not gonna use ... let me know if you're interested adn we can works something out. cheap too.
Old 09-03-2008, 04:35 PM   #22
Number98
Prestige Worldwide
Number98's Avatar
Number98 is offline   Reply With Quote
Old 09-03-2008, 05:28 PM   #23
noteron
noteron's Avatar
Hey Spraybomb I was thinking about running bags w/o a tank or compressor until I saved up more money for a drop-member from Poterbuilt. I just didnt think it would work. Where can I buy the schrader valves?
noteron is offline   Reply With Quote
Old 09-04-2008, 10:30 AM   #24
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
You can get the valves at any OREILLY auto parts, by the tire stuff.
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 09-04-2008, 09:35 PM   #25
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by noteron View Post
.... Where can I buy the schrader valves?
It will work just fine. You can find them on line as well as your local auto parts. If you do the front it will probably work better if your run a separate line/valve for each side. This will prevent air transfer from bag to bag and inhibit body roll.
Articles-
"Refining Sierra"
