RHCP afficianado
check out this engine
I found this engine on http://www.golensengineservice.com/ its only $2999.99 and makes 400 HP. what do you think of this one?
Specs: Crankshaft Eagle Nodule-Iron crank Connecting Rods Eagle Forged 5140 I-Beam rods Pistons Keith Black HyperEutectic pistons Rings Speed Pro Plasma-Moly Rings Block Thermally cleaned and Stainless-Steel Shot. Inspected by MPI process. Bored, honed and pressure washed. Clevite cam bearings and pioneer brass freeze plugs installed. Cam Comp Cams - Operating Range 2000 - 6000 RPM - Idle Quality Good - Duration Intake 230° @ .050" Exhaust 230° @ .050" - Lift Intake 0.48" Exhaust 0.48" - Lobe Seperation 110° Heads GM Factory - Type Iron - Combustion Chamber 70 CC - Intake Runner 150 CC - Intake Valves SBI Steel 1.94" - Exhaust Valves SBI Steel 1.50" - Head Gasket Fel-Pro - Compression Ratio 9.5:1 Rocker Arms Factory Stamped Steel Pushrods Comp Cams
~Ryan~ 89 S-10 Blazer with a 4.3L 96 Ford Crown Vic P71 4.6L V8. This car rocks. ![]() Here are some links to some good music. Jack Johnson Donavon Frankenreiter |
You get what you pay for
![]() Join Date: Dec 1999
Sounds like any other run of the mill 350 rebuild. Nothing special that I see. I don't like the head combo at all. They are just ordinary GM heads with 1.94 intakes. To tell you the truth, I don't see 400 HP from this engine. I also don't see $3000.00 for it either. At the most, this engine would probably make 350 HP. It would be pushing it then. The heads are what kills it. I think you can do a lot better than that for the money.
Mike 1985 Chevy C-10 |
STILL PLAYS WITH TRUX
I agree with mike if it had some brand name aluminum heads then you would see 400+ HP, as is NOT!
Look at all the different crate motor dealers out there and you will see the ones that claim 400 HP all use aluminum heads and get just about what that outfits asking maybe a little more. |
~THE SILVER BULLET~
ya i cant see that engine making 400 hp. the stock heads will hold it back a lot.
~1980 c10 chevy scottsdale~ ~2.5/4 drop 305/th350c~ |
driving is in my blood
no way thats at 400hp. For comparison, my 383 uses the same cam [comp magnum 280H] has 10.2:1 compression, vortec heads, and has 33cid over that engine and should make about 413hp.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
BAD BOW-Silverado XST
I'm gonna spend about 2/3 of that and I can probably say that I'll blow that engine out of the water. Them heads got to go. AFR baby!!!
RHCP afficianado
Yeah I think I'll just stick with my 383 setup and have someone build it for me.
Gerardo,
have you bought your heads yet? Which ones did you decide to go with, I know AFR's, but what size? And 2/3's of $3000.00 is $2000.00 and your intake, heads and carb will be that much. You get'in the block and other stuff for free? ![]() |
LOL@ G, your busted!
Hey messed up, whats the specs on the 383 you wanna build? Iron eagle heads good choice, but whats the intake port volume? Combustion chamber size? Piston type? Cam? Lets build a good combo ![]()
#10 | |
RHCP afficianado
I guess I should have said 7/8s for getting close to the final price. I already have the carb (q-jet will be later), intake (RPM-Air gap - FREE
![]() Heads are still a mystery. Some say the 185s out flow the 190s? I'm gonna have to look closely. I hope to get center bolt cover heads for the older intake styles. I think they are availble. |
G, you want 190's, maybe even 195's. I have not herd the 185's out flow the 190's before.....
#13 |
Maybe it was the 190 out flow the 195's. My choice is 190 but that's the one someone in a performance section was outflowed by another head.
