09-01-2008, 09:53 PM | #1 |
idk
i noticed thay when my truck is on it started tos moke today!
so i looked under and saw that there was some kind of oil all over the floor, and the oil was squirting on my headers wich caused it to smoke! so i go under my truck ti see if my pan was leaking or if it was my transmision! but everything was rite, so i pulled a plug and checked it and it was black and i had just got new plugs. it smelled like gas and oil? my carb is not flooding so i dont know whats cuasing this. do u? |
09-01-2008, 10:05 PM | #2 |
Re: idk
it sounds like your rings are bad and that you are fouling plugs,
have u had any reacent engine work done? is the oil visible on the headers? that could be a bad gasket
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) Last edited by drivethechevy; 09-01-2008 at 10:07 PM. |
09-01-2008, 10:12 PM | #3 |
Re: idk
i havnt had any recent work done, it never used to do this.
the oil comes i guess from the drive train if thats what its called. u knw the thing that turns between the tranny and the motor, the starter is kinda near it. |
09-01-2008, 10:20 PM | #4 |
Weldin' it up
Re: idk
that would be the torque converter
-Paul- RIP El Jay Dirt is for Racing, Asphalt is for Getting There If need be, send me an e-mail at cbm_racing_90@hotmail.com 1970 Custom/10 LWB 4X4 350/TH350 2003 Silverado 1500 Ext. cab 1974 Kawasaki 175 F7 Enduro 2002 Polaris Edge X 700 |
09-01-2008, 10:58 PM | #5 |
Re: idk
If theres gas in your oil your fuel pump is bad or your carb floats are too high causing it to dump in fuel and wash the cylinders down causing the smoke but I would check the pump first. Did an oil line come loose from the back of the block? Do you have aftermarket guages with the plastic oil line?
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
09-01-2008, 11:58 PM | #6 | |
Inline 69
Re: idk
if there is oil in between the motor and transmission,its probably a leaking rear main seal, if its coming out the exhaust possibly bad rings does your truck run idle ok? Any loss of power? jeff |
09-01-2008, 11:59 PM | #7 | ||
Re: idk
if you have a manual tranny it would be your clutch and flywheel, the torque converter and flywheel are for automatic trannys, if it looks like you are flinging oil onto the headers from the torque converter my guess is that the seal on the shaft under the torque converter, if the torque converter was pulled off at some point say for a tranny or engine swap the seal can dry out and crack alowing atf to leak from the torque converter which could cause it fling our from the inspection cover
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) |
09-02-2008, 02:31 AM | #8 |
Re: idk
thers nothing coming out of my headers.
09-02-2008, 05:53 AM | #9 |
Old Skool Club
Re: idk
Nor mine....they're laying on the garage floor
Sounds to me like you might want to take it and put it on a rack and have an experienced eyeball put on it. Do you have a mechanic friend that you trust who would help you figure out where the leak is? If oil is getting ON the headers, it's just like jef5150 suggested. You really need to get this thing up on a rack and start looking. Remember that gravity causes the leakage to drip to the lowest point, at which it may drop onto the pavement or a part of the truck. I'd suggest cleaning the engine to help in finding the source. It won't help determine internal problems, but it will help you find where the viewable problem may be.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
09-02-2008, 08:11 AM | #10 |
its all about the +6 inches
Re: idk
take it to a shop
09-02-2008, 01:50 PM | #11 |
Re: idk
Trueman |
09-02-2008, 03:44 PM | #12 |
Re: idk
here are some pics from were this oil is coming from!
i went under the truck to check if there was any loose bolts but nothing. |
09-02-2008, 03:50 PM | #13 |
It'll Buff Out!
Re: idk
looks like it is the rear main seal. is all that oil on the ground from ideling? You might even want to tow it in. tow+repair = cheaper then engine rebuild. good luck.
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB Last edited by So.Cal.Super; 09-02-2008 at 03:52 PM. |
09-02-2008, 04:20 PM | #14 |
Re: idk
if you're getting alot of excess gas weather due to bad carb or fuel pump or both i'd suggext checking your dipstick
09-02-2008, 04:41 PM | #15 |
Re: idk
yup its all from idleing
09-02-2008, 11:35 PM | #16 |
Re: idk
check the oil level and smell it. if it's is over full and reaks of gas then the carb is flooding and unburnt gas is going into the oil. if this is the case fix the carb and change the oil and filter before starting the motor.
Trueman |
09-03-2008, 12:08 AM | #17 |
Re: idk
not sure where all the talk of diluted oil with gas.... he has what looks like a leaking rear main seal.
09-03-2008, 12:11 AM | #18 |
Re: idk
i was told that probly my gasket wasnt good anymore and thats why it was leaking oil?
09-03-2008, 01:00 AM | #19 | |
It'll Buff Out!
Re: idk
But yes from those pics it looks like rear main. And if it's dumping that much oil at idle I wouldn't drive it. just my .02
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
09-03-2008, 01:26 AM | #20 |
Re: idk
so what do u think i should do?
09-03-2008, 01:43 AM | #21 |
Re: idk
the engine needs to come out, and the rear main seal (gasket) needs replaced more likely than not.
If you take it to a shop, they will probably recomend doing quite a few gaskets, and a timing chaing... and it's a good idea. |
09-03-2008, 07:04 AM | #22 |
Re: idk
rear seals may leak but i've never seen one cause plugs to foul ,10 quarts of oil&gas mixture in a 5quart pan has a tendency to leak , but what do i know? pull the engine like the experts advise it's far less effort than pulling a dipstick to rule out a possible cause of your leak and black plugs
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 09-03-2008 at 07:29 AM. |
09-03-2008, 01:55 PM | #23 |
Re: idk
can someone get me a 350 diagram that shows were the gasket is and how to put it on?
09-04-2008, 02:20 PM | #24 |
Re: idk
Go to the parts store, any parts store, and get a Chilton or Haynes Manual. Either one will show you how to replace the oil pan gasket (it is a fairly simple process) and rear main seal (not so simple, but not impossible). The oil pan will not require any special tools (just knowledge and patience). The rear main seal is under the rear main cap, and will require torquing when put back on. All of this can be done w/o pulling the motor, but........if it were mine, and the rear main was leaking that bad, I'd seriously consider pulling the engine and see what else might need to be worked on while I was in there. Especially if the motor's over-all condition was generally unknown. And from the symptoms you describe, it's getting a little tired.
My 2 cents Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! Last edited by Psycho71; 09-04-2008 at 02:21 PM. |
