Old 09-01-2008, 10:58 PM   #1
67C10SWB
What Starter do I need?
Need some help if someone could take the time.. Question I have is I'm swapping out the stock truck 4 speed in my 67 C10 to a 700R4 from an 87 suburban. I have the 292 in the truck and I will need a starter that mounts to the block instead of to the bell housing. Is this a small block chevy starter with the in-line bolt pattern? Thanks, Mike
67C10SWB is offline   Reply With Quote
Old 09-01-2008, 11:28 PM   #2
70cst
70cst's Avatar
Re: What Starter do I need?
Here is a bump for you. Hopefully someone can chime in with some helpful info.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 09-02-2008, 12:02 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
why not just get a starter for a 292 with an automatic?
Old 09-02-2008, 11:08 AM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
It will depend on whether you use a 168 toothed flywheel or a 153.
168 uses a stagger, 153 uses inline bolt pattern
sneakysnake is offline   Reply With Quote
Old 09-02-2008, 08:52 PM   #5
67C10SWB
Thanks for the replies. I pretty much figured the 292 auto starter would be what I would buy, but was hoping it might be the same as a SB starter, I will get with the local parts store tomorrow. Thanks again...
