Old 09-02-2008, 11:02 AM   #1
my67chevytruck
Under Construction
my67chevytruck's Avatar
removing mc on a 72
Hello,
me and my son have removed the front crossmember off the 72 for the swap into his 67.
I have not spent much time but did take a look. Is there any tips /tricks/suggestions of removing the complete mastercylinder/booster from the firewall. I did look under the cab and see a plate and 4 bolts that will need to be removed, and also a bolt with a nut and cotter pin attached to the brake pedal. but it seem that the stud will hit the column. can this be removed without removing the steeering column? should i take the whole pedal assembly to use on the 67 or will it mate up?
Thanks..
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 09-02-2008, 02:19 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: removing mc on a 72
Four bolts hold the assembly to the firewall and the pedal support on the inside. There is the link from the pedal to the booster. One of the lower bolts also serves to retain the steering column. I pulled the column on my truck this weekend, but left the M/C and booster assy in place.
If you don't yet have an assembly manual, you should consider getting one. The pictures are the resource. There isn't much organization of the info, short of the chronology of the pages. But being able to look at the pictures, after you have also been intimate with the truck, will enable you to better understand how it all goes together....or comes apart.
The shop manual will also provide some help.
Both of these books are available as reprints....I recommend them.
Member Nr. 2770
Old 09-02-2008, 02:28 PM   #3
my67chevytruck
Under Construction
Thanks for the reply. I will look into this.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 09-02-2008, 05:31 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Once the bolt is loose on the pedal arm you can depress the pedal(It will be easier after the booster/MC is removed) and pull that bolt out.Keep track of which brake rod goes with what since they are different.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-02-2008, 09:20 PM   #5
my67chevytruck
Under Construction
Thanks for the replies. I had to remove 2 bolts that held the column up from under the dash to get the bolt out that went through the brake pedal.
success.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
