Old 09-02-2008, 01:11 PM   #1
jkaylor68gmc
jkaylor68gmc's Avatar
Thumbs up Going to the Dyno at 6:00 (sure I'll be dissapointed)
O.K. so many of you know I drive a yellow '47 International every day to work and various shoots, however, it is time to beef up the old 310-incher with some hot new parts, mainly because I am in a HP race at work, (number envy, its a long story.)
So editor Tommy Lee is packing a '64 Corvette with a Dart headed 350, it makes about 287 horsepower at the rear wheels (dynoed)
The yellow IH is packing a 305ho that is punched out to 310 cubic inches (0.030 overbore, Comp 440 lift cam, 10.5 to 1 flat tops and iron 58cc heads. Edelbrock intake and a 500cfm carb.
I am taking it down the street today to get a baseline number.
I am going to install a set of High Velocity Heads, sbc aluminum heads, 175cc intake runners, 2.02/1.60 valves and beehive springs along with a new vortec style manifold and a Holley 650cfm carb.
Hopeing to at least get 200 the first go around, but we will have to wait and see. I'll be sure to post the results in the morning.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 09-02-2008, 01:14 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Going to the Dyno at 6:00 (sure I'll be dissapointed)
I'm really partial to old Cornbinders....
Yeah, we're gonna be watching to see how this turns out. Good luck. Hope you don't "blow" it...
Member Nr. 2770
Old 09-02-2008, 01:23 PM   #3
lowriden58
lowriden58's Avatar
Good luck! i can tell you that when i dynoed the 71 i was dissapointed
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 09-02-2008, 01:31 PM   #4
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
That's funny
LOW DOUGH is offline   Reply With Quote
Old 09-02-2008, 01:44 PM   #5
jkaylor68gmc
well, I saw how Tommy's Corvette did, made me sad. Rumor is these heads will make the truck hit 300 at the rear wheel or so I am told.
probably the combination of the new heads, bigger carb, better intake, aluminum roller rockers, Weiand aluminum water pump and carb spacer.
1962 swb fleetside
Old 09-02-2008, 01:50 PM   #6
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Well, GOOD LUCK to you.
Let us know what it did.
Old 09-02-2008, 02:06 PM   #7
jkaylor68gmc
I will
1962 swb fleetside
Old 09-02-2008, 02:12 PM   #8
70rs/ss
70rs/ss's Avatar
I took a summer class at UTI a few years back and the last day or two they let us play around, well I put my 94 9C1 Caprice on the rollers, 265 with a K&N FIPK kit and and flowmasters added intot he factory duals. I was shocked a bit, then realized what the flywheel numbers should be and what that motor would do in a car that was a thousand pounds lighter (4500 lbs or so in the caprice), then I wasn't so upset! Dyno's don't lie isn't 100% true, so do not get too down on yourself since there are a lot of variables on a chasis dyno.
70rs/ss is offline   Reply With Quote
Old 09-02-2008, 02:24 PM   #9
Myself
I'd like to see the 305 put up some big numbers. I've got one in my S10 Blazer with ported, and port matched H.O.heads, 9.5:1 Speed Pro pistons, Crane cam, roller tipped rockers, Action plus intake, Mallory distributor, Street Avenger 570 carb, Hedman shorty headers, and true duals that puts about 250 to the wheels. Propels my 3800# suv to a 2 sec 60ft and a 14.90 1/4 mile at 94 mph! Not too shabby for a mildly built 305. The only reason I didn't go more radical was because it's my everyday driver. And it gets 16mpg in town. I'd guess 300hp from a 305 would be pretty easy to accomplish, and 400+ from a 305 stroker.
Myself is offline   Reply With Quote
Old 09-02-2008, 02:36 PM   #10
jkaylor68gmc
thats good to know, I am going to a DynoJet which is suppose to be 20 percent higher than a Mustang. Not real sure though.
my truck weighs 2685 with 3/4 of a tank of fuel.
1962 swb fleetside
Old 09-03-2008, 07:18 AM   #11
c10crazy
Like a Rock!
c10crazy's Avatar
I predict you will make close to your buddy's 350
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 09-03-2008, 08:45 AM   #12
jkaylor68gmc
O.K. so I went to the Dyno and I am sad, i feel that I have been touched wrongly.
The best run up to 4 was the red line 145 horsepower, OUCH!
We found that the throttle pedal was not pulling the carb to wide open throttle.
AFter making the adjustments we hit 175 horsepower and 242 on torque.
I was sad but with the new top end and maybe a FI kit later I should be able to hit 300. We'll have to see, I am about to begin the teardown.
1962 swb fleetside
Old 09-03-2008, 08:48 AM   #13
jkaylor68gmc
Here is the dyno sheet, you can see the difference between 3/4 throttle and full throttle.
1962 swb fleetside
Old 09-03-2008, 08:54 AM   #14
68Stepbed
68Stepbed's Avatar
I suggest keeping the 500 cfm carb. The 650 will bog it down at lower rpms. It might make more peak HP, but throttle response and driveability will be better with the 500.
With all things considered, 175 at the rear wheels with a 305 is pretty darn good. That means your touching the 250-275 hp mark at the flywheel with accessories. If the engine were on a dyno with no accessories, it would probably be in the 300-315 range.
I doubt my mild cammed 350 would do that well.
Also, if you don't mind me asking, where did you have the dyno done and about how much does it cost? I'm interested in having my truck dynoed just for the fun of it.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 09-03-2008, 08:56 AM   #15
jkaylor68gmc
He told me I would be making a ton more at the crank but I have the three biggest power killers
700R4
12 Bolt truck rear
Massive 20-inch rollers with big tires.... oooppppss
1962 swb fleetside
Old 09-03-2008, 09:20 AM   #16
ulakovic22
He's right, the 12 bolt doesn't hurt you too much. What kinda stall are you running, they will eat up the power on a dyno.
ulakovic22 is offline   Reply With Quote
Old 09-03-2008, 09:22 AM   #17
jkaylor68gmc
I am not quite for sure, I will have to try and find the dyno report for my trans, it is a TCI deal.
He said the 12 bolt WAS hurting me.
1962 swb fleetside
Old 09-03-2008, 09:35 AM   #18
ulakovic22
It does hurt you compared to a 10 bolt sure, but it's not going to suck up 20+ rwhp. On 4th gen Camaro's 12 bolts only take maybe 10-15 rwhp to spin up. The wheels take up a lot of power, I lost about 10 just switching from factory 16's to chrome 18's, so I bet 20's are even worse. The biggest culprit is your auto and whatever stall you are running.
Old 09-03-2008, 09:46 AM   #19
jkaylor68gmc
yeah, I know, just means I will have to make more power at the crank. The dyno guy told me I might be losing as much as 30 percent. Thats O.k I look good doing it.
1962 swb fleetside
Old 09-03-2008, 10:34 AM   #20
67ChevyRedneck
67ChevyRedneck's Avatar
What's important is do you enjoy driving the truck?
But seriously, that's some nice power for a 2,700lb truck!
2.2L S-10's only make about 88-90 hp at the rear wheels (no I'm not joking ) and they weigh 3,100lbs (2wd reg cab) and up.
My 67 weights about 3,700lbs and I'd be lucky if my late 70's 350 makes 200 hp at the flywheel
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 09-03-2008, 11:04 AM   #21
jkaylor68gmc
yeah, I just want some more power and the dang office race isn't helping anything either.
WIll/ Super Rod Cadillac CTS-V 365 horsepower at the wheels
Tommy/ Chevy RUmble '64 Corvett 286 horsepower at the wheels
ME / Truck Builder '47 IH 175 horsepower at the wheels.
1962 swb fleetside
Old 09-03-2008, 11:05 AM   #22
jkaylor68gmc
I have alot of catching up to do.
1962 swb fleetside
Old 09-03-2008, 11:16 AM   #23
67ChevyRedneck
Just drop one of these in instead. You may need to beef up the 700R4 for it though...
http://www.edelbrock.com/media/news/.../081407-9.html
*It's a little bit on the expensive side
Jesse James
Project "On a Dime"
Old 09-03-2008, 11:25 AM   #24
jkaylor68gmc
Ya think? I would rather keep my short block, it new, clean, runs great, just a few bolt-ons is all.
aluminum heads, new intake, bigger carb, roller rockers, new pushrods and an aluminum water pump should do the trick.
1962 swb fleetside
Old 09-03-2008, 11:39 AM   #25
67ChevyRedneck
Yeah, just givin' you an "ass kickin'" option
Do you have a clutch fan or electric fans? That's good for a couple/few hp as well.
Jesse James
Project "On a Dime"
