09-02-2008, 06:15 PM | #1 |
How to get electrical into the gas tank?
I am stuck and need your help. I am building a gas tank for my truck and I need a way to get the electrical into the gas tank for the fuel pump. I am planning on using a aeromotive a1000 pump sumberged in the tank and can't find any kind of electrical bulkheads or some sort of connector to get the electrical into the tank and sealed so no gas leaks. Any help would be much appreciated. Thanks
Josh
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
09-02-2008, 07:00 PM | #2 |
Re: How to get electrical into the gas tank?
I would recommended getting the factory GM unit (fuel pump, fuel level sender/sump can) and making it fit the tank your building.
Edit: You should still be able to use the pump you have with the GM unit. Something like this: http://cgi.ebay.com/ebaymotors/GM-FU...spagenameZWDVW
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 09-02-2008 at 07:02 PM. |
09-03-2008, 02:10 AM | #3 |
Check out Tanks Inc. I think they have something like you're looking for
09-03-2008, 09:26 AM | #4 |
It's a catastrophic success.
I know sump and submerged pumps use a compression grommet for their cords, but as mentioned I think the original fuel tank sender and connection may be a safer route.
09-03-2008, 11:29 AM | #5 |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 09-03-2008 at 11:29 AM. |
