Old 09-02-2008, 07:37 PM   #1
(joey)
(joey)'s Avatar
any one shave there drip rail?
my drip rail is shot and im in the middle of hacking it off .just wondering if anyone has pics of this done?
(joey) is offline   Reply With Quote
Old 09-02-2008, 08:37 PM   #2
ERIK D
ERIK D's Avatar
Re: any one shave there drip rail?
check this out,and see my build thread
SILVER BULLET
ERIK D is offline   Reply With Quote
Old 09-02-2008, 08:40 PM   #3
ERIK D
ERIK D's Avatar
One more
Old 09-02-2008, 09:24 PM   #4
Shane
Shane's Avatar
Awesome looking truck Erik!
Shane is offline   Reply With Quote
Old 09-03-2008, 12:22 AM   #5
jonnybravo
jonnybravo's Avatar
i dont have any pics but in mag like ct or cct they did it , they said you have cut a couple inches out and then weld and so on and so on. evidently the drip rail holds the cab together
jonnybravo is offline   Reply With Quote
Old 09-03-2008, 10:58 AM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
There are three pieces of metal that come together at that point. Cut it wrong and you'll need another cab. I think you should also brace the cab to keep the dimensions correct while you work on it. Simply cutting off the drip rail may sound like a no-brainer, but be sure of what you're doing before you start.
I can take a picture of a cab that had new corners, floor pans and rockers, and a dash from a '96, that was not braced before the rails were cut off. The cab is trash. Oh the firewall was reworked and smooth, too. Those guys had a ton of work in the cab and it all went to pot.
Member Nr. 2770
Old 09-03-2008, 12:04 PM   #7
raggedjim
raggedjim's Avatar
Nope, but I've bought parts from projects from guys who started doing it but couldn't finish it up. I always encourage people to do this, I need more parts!
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 09-03-2008, 12:34 PM   #8
68_chop_top
68_chop_top's Avatar
This is how Chevy pinched the inner and outer panels together. When I cut mine, I went back and welded them together and grinded back smooth.
Mine is chopped, has a clutch, and a big block.
68_chop_top is offline   Reply With Quote
Old 09-03-2008, 04:40 PM   #9
(joey)
(joey)'s Avatar
thanks for the replies.yeah im just cutting sections so far.i have a welder home now so im going to do a little at a time.and from what im seeing i think it makes the truck look so much cleaner.68_chop_top that looks so good.i was thinking of doing the same thing but didnt know what to do about a side window.what did you do for side door glass to suck back the whole front windsheild and pillars like that?
Old 09-03-2008, 05:14 PM   #10
68_chop_top
See my pictures in my gallery, should answer alot of questions.
I didn't cut my windshield, just laid the A pillars over. For the side glass, just had flat glass cut to fit.
