Old 11-16-2002, 08:26 PM   #1
gashog
Active Member
gashog's Avatar
Question Billit grill hood latch?
I'm installing a billit grill in my 69 using a 72 shell and latch assembly. Since I can no longer access the latch thru the grill, I was thinking of either welding on an extention or going with some kind of remote. Any idea's?
69 Custom/10 454 Turbo 400 and 70 Custom/20 350 Turbo 350, 73 cheyanne C/10 also 69 camaro Z/28 and 85 Iroc Z
gashog is offline   Reply With Quote
Old 11-16-2002, 10:38 PM   #2
barn9
Half a bubble off!
barn9's Avatar
Try search, this has been covered in the past. I seem to remember that some used a rod that went down to where you reach under the bumper to open the latch, and also some used a remote cable type hood release kit from J.C. Whitney. Keep us posted, I'm thinking of getting one myself.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 11-17-2002, 04:15 PM   #3
gashog
Active Member
gashog's Avatar
Hey Barn 9 Thanks for the help. I found the post you were talking about, I went with the extention rod, it was easy and seems to work fine.
Old 11-17-2002, 04:25 PM   #4
BIG ORANGE
BIG ORANGE's Avatar
Smile hood latch
Glad you found the thread,I had a neat set up on the burb,put a bracket on the bottom of the radiator support and a hime joint in the bottom of the latch with a rod running through the bracket on the support it worked fine.
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 11-17-2002, 06:51 PM   #5
CustomChevy
inside hood latch?
if you are looking for inside hood latch and cable, you can try lokar.
www.lokar.com
good luck!
CustomChevy is offline   Reply With Quote
