09-02-2008, 08:48 PM | #1 |
6.5 diesel in 4x4 1970 w/no body lift??
Hey people. I want to put a diesel in the 70 4x4. A Cummins or a 6.5. I have both that I can use, but am leaning towards the 6.5.
My question is: In a 4x4 67-72 has anyone done it without any lift or atleast without any body lift? I have a big block in it now and to make it fit I had to modify the firewall and use 3" body lift. I want to remove the body lift and install a 6.5. Will it fit?
1970 4X4, Big block 454, 4 speed, vintage air, Mahagony wood bed, Tilt, tach. Can have new owner for the right price. "Life is tough, its tougher if you are stupid" (John Wayne) My buddys truck for sale here. http://67-72chevytrucks.com/vboard/c...p?product=2676 Last edited by Keep on Trucking; 09-02-2008 at 08:50 PM. Reason: Its a secret |
09-02-2008, 09:34 PM | #2 |
Resident of Here
Re: 6.5 diesel in 4x4 1970 w/no body lift??
I would put it in now, and then see how much room you have left with the lift.
Also, can I have the Cummins?
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
09-02-2008, 09:41 PM | #3 |
The 6.5 will fit without any mods if it has the sepentine belt. I put a 6.5 in a 68 4x years ago without any mods what-so-ever. No body lift, no firewall mods. Same dimensions as the big block. Used the big block radiator and shroud.
09-02-2008, 09:59 PM | #4 |
If you can be here in the next five minutes, its yours.
1970 4X4, Big block 454, 4 speed, vintage air, Mahagony wood bed, Tilt, tach. Can have new owner for the right price. "Life is tough, its tougher if you are stupid" (John Wayne) My buddys truck for sale here. http://67-72chevytrucks.com/vboard/c...p?product=2676 Last edited by Keep on Trucking; 09-02-2008 at 09:59 PM. |
09-02-2008, 10:05 PM | #5 | |
Did you move the engine forward on the 68?
1970 4X4, Big block 454, 4 speed, vintage air, Mahagony wood bed, Tilt, tach. Can have new owner for the right price. "Life is tough, its tougher if you are stupid" (John Wayne) My buddys truck for sale here. http://67-72chevytrucks.com/vboard/c...p?product=2676 |
09-02-2008, 10:06 PM | #6 |
Well, Whoop-dee-do!
I'd have to see it to believe it. No mods AT ALL? I have a '68 4x4, and you could try to make it fit seven ways to Sunday, it isn't going to bolt in without serious mods. I set a 6.2 in a '72 4x4 once. The driver's head hit the firewall before it was even close to the bellhousing, and the exhaust manifolds were sitting on the frame with the mounts far higher than where they would bolt to the crossmember, which the crossmember would not have worked because the oil pan was too big, and the clutch cross shaft was a no- go/ no- way...
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD '72 K20 500 Cad/TH400/NP205 SOLD '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car |
09-02-2008, 10:21 PM | #7 | |
Things that will help me. 1. when I did the BBC in it now I clearenced the firewall. When I did that I lost the use of the original clutch, so I went with a hyd throw out bearing and a master cylinder. 2. I put in the 1973 style engine xmember as the original would not fit with the oil pan I used. I think the 6.5 SHOULD go in, in this case. I think a 6.5 is smaller overall size than a BBC.Anyone know for sure? Oh yea I will be running a 4L80E trans with it.
09-02-2008, 10:30 PM | #8 |
Well, Whoop-dee-do!
Your mods should make it pretty easy. The '73 up crossmember "stands" should be replaced with 6.2 stands- they are slightly different. I think you can get the gas stands to work, I can't remember the actual difference, but I know I always had to swap them when going from 6.2 to 350.
Keep us posted w/ pics when you start on it!
09-02-2008, 10:40 PM | #9 |
On my 96 6.5 the frame side mount has a 90 degree bend in it and the gassers are flat. I think dimentionaly they are the same so ethier should work once they are mounted.
My main objectives are to get a 6.5 in it and be able to remove the body lift. thirdstreettito, times up.
09-03-2008, 06:16 AM | #10 |
A Detroit-Allison 6.2/6.5 has the same footprint as a BBC.So....
I know they`ll drop right in a 2wd.We know a 4wd is another story. Not sure if you are aware,but if it`s a 6.5TD the heater and the turbo/downpipe will be fighting for space.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 09-03-2008 at 06:18 AM. |
09-03-2008, 10:41 AM | #11 |
By footprint do you mean bellhousing bolt pattern? Yes they are the same.
I also have Vintage Air installed with the flat fire wall, so I hope I will be ok there. Thanks.
09-03-2008, 09:07 PM | #12 |
I mean all around & overall:height,width,length.I think they need pretty much whatever space a BBC needs.
09-03-2008, 09:34 PM | #13 |
OK thanks.
Im going to start on this project next month when the weather starts to cool off. I will take lots of pictures.
09-03-2008, 09:36 PM | #14 |
I have a radical idea!
I'll agree with Special K on that. The small block mounts seem to mount them too low. I am going to use either BBC or GMC V6 frame mounts on my '67 C-30.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
09-03-2008, 09:45 PM | #15 |
I have the 73-up xmember and the 73-up style engine mounts they are from energy suspension, the urethane kind.
Do ya'll see any problems with using those? Im pretty sure this thing will just about fall in there with it allready having a BBC in it now, but its the little things that can sneak up and bite you/me.
09-03-2008, 09:54 PM | #16 | |
09-04-2008, 12:19 AM | #17 |
These are the only pics that I have of the install. Yes there was a small suspension lift on the truck, and the engine was installed in the 2wd big block location
09-04-2008, 11:19 AM | #18 |
OK very cool.
So is what you are saying is your engine is mounted more forward than normal? I guess you would need to mod drive shafts, trans xmember, tcase mounts ECT...... right? What trans did you use? I am going to go with a 4L80E. You used a suspesion lift, did you use/need a body lift? Any more pictures of the finished install? I also see its a 6.2 so you did not have turbo clearence issues. By looking at your pic's it looks like a 6.5 turbo will fit in mine. Thanks again for the pictures.
09-04-2008, 03:37 PM | #19 |
No more pics, those are the only ones.
That is an early 6.5. Yes I did drivelines, I was running a th400 with a Gear Vendor OD with 3.73 gearing. The build was a complete frame off, so everything was stripped off. That pic was taken b4 the turbo was installed. I used an ATS exhaust manifold. That was fun trying to buy as they do not ship into Calif.. Had to do an end run around thru a friend in Oregon to get the manifold. The Banks manifold will not fit as it want to hit the radiator. The ATS manifold brings the turbo up between cyls 1&2. It is out of the way of the heater box that way. Last edited by kwmech; 09-04-2008 at 03:40 PM. |
09-04-2008, 05:09 PM | #20 |
How do you like it now that its done? Anything you would have done different?
I have a 6.5 non turbo intake (like the one in your picture) that I powder coated red and that I will be listing on ebay. I was going to use it with a custom inlet ducting. I think we would all like to see pictures of your finished truck!! I just tought about something:: is your truck 2WD or 4x4? If it is 4x4 how did you set up the GV overdrive? Thanks.
09-04-2008, 05:56 PM | #21 | |
09-04-2008, 05:58 PM | #22 |
BTW, as far as I can tell the factory heater box is not going to work with the 6.5TD set-up. It appears that the turbo is going to hit right where it will be, but I'm not sure yet. I planning on going with Vintage Air, so it doesn't matter to me.
09-04-2008, 06:52 PM | #23 |
Hey how did you get that picture of my engine.
I want to post a picture of my intake but keep getting this message. "The Dimension limits for this filetype are 642 x 0. We were unable to resize your file so you will need to do so manually and upload it again. Your file is currently 1280 x 960. " I don't think I can resize my pic's down to 0 can I. Am I limited on the amount of attachments I can have on this site? cause I have posted a few pictures allready. Also I will be needing to round up the complete serp belt system for the 6.5
09-04-2008, 06:56 PM | #24 |
Ive allready got the Vintage air and it blows snow balls. Another problem for me is I will have to figure out how to mount the sanden A/C comp.
09-04-2008, 10:05 PM | #25 | |
You'll need to downsize them with some kind of editing software or you can set a free photobucket account and link to them.
