Old 09-02-2008, 11:52 PM   #1
cstm68
cstm68's Avatar
e-brake
what type of e-brake are you guys with rear disk brakes using. shoe type or calpier type, ???
what rotors and calipers work best?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 09-03-2008, 02:15 AM   #2
Keep on Trucking
Keep on Trucking's Avatar
Re: e-brake
I used 1977 style Eldorado rear calipers. Have the ebrake built into them. They are very big calipers (for stock) they are the same size as the 3/4- 1 ton front truck calipers and will actually interchange with the Eldo's but no ebrake.
I would like to find an updated system with 4 or more piston calipers and larger disc's for a 8 lug. Mainly for the "cool" factor as my brakes work well now.
1970 4X4, Big block 454, 4 speed, vintage air, Mahagony wood bed, Tilt, tach.
Can have new owner for the right price.
"Life is tough, its tougher if you are stupid" (John Wayne)
My buddys truck for sale here.
http://67-72chevytrucks.com/vboard/c...p?product=2676
Keep on Trucking is offline   Reply With Quote
Old 09-03-2008, 10:40 PM   #3
cstm68
cstm68's Avatar
Re: e-brake
what rear rotors did you use
Old 09-03-2008, 11:17 PM   #4
Keep on Trucking
Re: e-brake
I was going to use Chevy's, but looked a some ford's just to see what they looked like and they actually have more offset and worked better. Mine are off a 79 ford, fronts with 4x4.
I have the corporate rear axle The size ring gear escapes me right now. I think 10.5"
