Old 09-03-2008, 09:35 AM   #1
manimal
manimal's Avatar
56" rear springs?
.......on a SHORTBED?
My '75 GMC short stepper has 56" rear springs and the SPID says HD rear springs. Is this very common? it has 7 leaves PLUS the big main leaf. How many can I remove to lower it and still have a decent ride? Thanks
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 09-03-2008, 12:00 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: 56" rear springs?
I personally wouldn't take more than 3 out of a 7 leaf HD pack. (you can ditch the helper if you don't plan to load it down)
HD springs on a stepside isn't out of the ordinary.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 09-03-2008, 01:10 PM   #3
Pyrotechnic
Pyrotechnic's Avatar
I actually prefer these springs. The longer length gives a better ride if you remove one or two. Also, if you want drop shackles, you don't have to cut the bed supports like you would with shorter springs.
On mine, I remove the the huge helper and then one of the upper leafs that didn't have much spring rate to it. Removing the helper lowered the rear slightly to make it more level with the front and the other leaf softened up the ride but I can still put a heavy load in the back with no sagging.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
