Windy Corner of a Dirty Street
Aux fuel tank LH side or RH?
I am in the process of ordering a sending unit to convert the truck to an in-tank fuel pump and cannot remember which side is considered the Auxiliary tank. If memory serves me right, the Aux tank is the driver side but not certain. I want to make sure I order the sending unit for the RH (Passengers side).
All the part numbers state Aux or non-aux….you would think a simple LH or RH description would be used in the parts catalogs ![]() Thanks!
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Aux fuel tank LH side or RH?
my 86 was a single tank and it was on the leftt side tank hope that helps
now to add to the confusion....lol My 77 with a single tank had it on the passenger side.
![]() Join Date: Jun 2007
I believe the 73-78 aux was on the left. When the primary tank was changed to left in 79, aux was on the right. ...Joe
I'm not speedin'! I'm qualifyin'! |
Navy Radioman Veteran
Didn't some older vehicles have an indicator on the fuel gauge showing the location of the tank so you'd know which side to pull up to if you forgot which side it was on??
My '87 had 2 tanks, the switch says LH and RH. Switch still works but only one tank in it now... LH. Reason I know is, I recently hit the switch by accident and then engine died a short while later and wouldn't start.. I felt pretty stupid an hour later when I finally figured it out. ![]()
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side - At the Body Shop Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside |
funny i dont feel so stupid now that ive heard your story and done the same thing!
Georgia Boy
My 81 GMC 2wd has one tank and it's on the drivers(left) side..
Thanks guys….That is what I thought….When I was thinking about trucks I played with in the past it seemed as if I had seen single tanks located on either side on different trucks before. I was starting to think I was crazy.
I am changing to a 1987 fuel tank in order to use an EFI sending unit for use with a in-tank fuel pump to rid this thing of the POS frame mounted electric pump that overheated and left me stranded a few times last weekend when cruising the trails in the high country. So, it looks like the RH would be the Aux side for 1987?? (figures...the Aux sending unit is $20 more than the other). The EFI sending units are different from side to side on the square bodies so I want to make sure I order the right one for the RH side. The LH tank will remain 1978 pieces but run a transfer pump to feed the RH tank as the fuel tank switch valve will not work with the fuel system on this Vortec 8100. The Polluk switch valve is too restrictive on the return line side causing the fuel pressure to constantly run around 100 psi, which is way too much pressure even for this hog.
I'm 44 yrs old and the only thing I know about Pueblo is one of it's zipcodes. 81009. I remember that from some public service announcement when I was a kid... funny how some things stick with you!!
![]() Good luck with with sending unit. Kenny
#11 | ||
Until Seventy Times Seven
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
The standard side of a 73-78 is the passenger side.
The standard side of a 79-87 is the drivers side. BTW, I found my valve Larry and it is 65PSI....
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#13 | |
My '79 and '80 are both single passenger side fuel tanks from the factory
'70 Pontiac Firebird Esprit '72 GMC 2500 '90 GMC V1500 '94 Dodge Cummins 2500 '02 Dodge 2500 Quad Cab Long Box 4x4 gasser ![]() |
#14 |
As Far as US trucks goes this is pretty much true. There were trucks that were equipped with leftover passenger side fills just like all their other GM transitions.
I know nothing about Canadian Truck changes.
