One of the few GMC'ers
Tire gonna fall off?
Ok so my truck just recently started doing this. When i stop at a stop sign and turn/take offit kinds feels like my truck wants to keep steering after i straighten the wheels back up. almost feels like the tires are wobbling, but i had it jacked up and tried shaking the tire... they are tight. uhhh they are also wearing way bad on the outsides of the tires. i know i should take it to a alinment shop but im a find out what it is first kinda guy
ohh i forgot to add it started doing this right after i had it jambed in sum sticky @$$ mud
87' ![]() "Young, Dumb And Full Of Cum" Last edited by TireSmoke420; 09-03-2008 at 06:41 PM. |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Tire gonna fall off?
you need to check the tie rod ends and the rest of the front end for play
1962 C-10
And re-grease everything...
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
ohh yea i lubbed her up real good i thought at first it might be sticking but its not
87' ![]() "Young, Dumb And Full Of Cum" |
great southern land
could you have some mud still stuck somwhere around the hubs or brakes? if the wheels shaking you could have mud stuck to the inside of the rim and throwing the balence out?
rod ![]() 86 chevy c10 silverado |
it only does it whn i stop and turn from like a light or stop sign it happens when i strighten the wheels back up
You didn't happen to fasten the tow strap to your tie-rods, or center link, did you? Sounds like you have a serious "Toe In" issue. Do you smell burning rubber when you're driving 30 to 40mph? If you do, then it's time to see your alignment shop. NOW. Don't drive it until you can "see" the air in your tires.
Check your alignment shims in your upper control arms. I had the same problem with my 78 the shims would fall out and I the wheel would move froward and back when braking and turning from a stop. This would also wear out the outside of your tires. I would also get a clunk noise while braking.
no i hooked the chain to the front leafs. and no i do not smell burning rubber. dont get any clunking sounds. i did however find out the drag link feels loose i grabbed a hold of it and twisted... how much should i be able to twist that thing?
ok im able to twist the tie rod as well
bushings and tie rod issue
86 c-10.. new project truck i'm 2nd owner 97 jimmy... wife truck |
