Old 05-09-2002, 09:13 PM   #1
THECRAZYKIDJR
Post NEED HELP WITH WIFE S10
I KNOW ITSTHE WRONG BOARD, BUT I'M HOPING SOMEONE ON HERE CAN TELL ME THE PROBLEM....
93 S10 BLAZER 4.3 5SPD 4WD 111,000 MILES
WAS ACTING LIKE IT WAS CROSS FIRING ONLY WHEN RAINING OR DAMP OUT, THEN JUST ALSO WHEN IT SAT AND WAS COLD AT STARTUP...IT WOULD RUN NORMAL AFTER IT GOT UP TO TEMP
DID A FULL TUNE UP, PLUGS, WIRES, CAP, ROTOR, AIR & FUEL FILTER
NO CHANGE...NOTICED THE CAT WAS CHERRY RED AFTER I GOT IT TO TEMP...GONNA CHANGE THAT
ALSO NOTICED THAT IT SOUNDS LIKE ITS NOT SPRAYING FUEL RIGHT...KINDA SKIPS
OXYGEN SENSOR? MAP SENSOR? EGR? AIR INTAKE SENSOR?
BY THE WAY ....NOT FLASHING ANY CODES!!!!
HELP ME!!! MY WIFE IS DRIVING MY TRUCK UNTIL ITS FIXED, I WANT MY TRUCK BACK!!!!!!!
JIM PARKER
THECRAZYKIDJR
GLENBURN, MAINE
REMEMBERING DALE EARNHARDT 1951 - 2001...RIP
1999 DODGE DAKOTA SPORT 4X4 (31" BFG ALL-TERR KO'S)
1969 K5 BLAZER (ORANGE / 35" SUPER SWAMPERS)
1970 CUSTOM-10 LONG BED FLEET/350/4SPD/PS/PB/AIR/TILT/TACH/VAC/AM-FM/SPEED MINDER/WOOD FLOOR BED/SLIDER/CARGO LIGHT/BUCKETS&CONSOLE/TINTED GLASS/HEADLINER/AUX. REAR SPRINGS/TOOL STOWAGE BOX
(STILL AT THE RESTO SHOP, GETTING PAINTED)
JIM PARKER
GLENBURN, MAINE
69 BURB 4WD - 307/4SPD/YELLOW
69 BLAZER (ORANGE / 35" SUPER SWAMPERS)
1970 CUSTOM-10
THECRAZYKIDJR is offline   Reply With Quote
Old 05-09-2002, 09:19 PM   #2
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
Post
my guess would be partly EGR but check engine shouldcome n from it, m bro has a 93 tahoe blazer with 4.3 vortec, and ti sounded like sh*t, we pulled it off, and it was really built up with carbon, and was stickin, cleaned it up, started it once with out it on, blew some carbonoutta the motor, then put it backon, ran way better.. hope I helped,
Bryce
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 05-09-2002, 09:21 PM   #3
Randy70C-10
Randy70C-10's Avatar
Post
Uhhhh, the cat turning cherry red could be the problem. You exhaust is stopped up!
Randy70C-10 is offline   Reply With Quote
Old 05-09-2002, 09:22 PM   #4
cableguy0
Post
does it have a check engine light on. run some fuel injector cleaner through it first i would use the chevron techron b/c it is the best sh!t on the market. need to know if there is a check engine light or not
72 chevy lwb 350 lunati cam ported and polished cast 2.02 heads proform hei edelbrock performer rpm and 750 carb balanced bottom end 9.5:1 compression ps,pb th350 with a tci 2500 stall convertor full man v-body kevlar clutches and bands as well as other goodies
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 05-09-2002, 09:25 PM   #5
Don Smith
Post
Definitely an electrical problem. Dist cap may have a hairline crack and moisture causing it to arc between terminals or to ground, also could be wires arcing. Get in total darkness and look at engine while it is running, you may be able to see arc or hear it.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
Old 05-09-2002, 09:26 PM   #6
Randy70C-10
Post
He changed the cap.
Old 05-09-2002, 09:48 PM   #7
THECRAZYKIDJR
Post
DID A FULL TUNE UP
NO CHECK ENGINE LIGHT, NO CODES, ALREADY TRIED INJ CLEANER
RANDY, I'M GONNA CHANGE THE CAT, BUT WHY WOULD THE CAT ONLY GIVE THE PROBLEM WHEN COLD, INTERMITEDLY??? WOULDN'T IT DO IT ALL THE TIME?
JIM PARKER
THECRAZYKIDJR
GLENBURN, MAINE
JIM PARKER
GLENBURN, MAINE
1970 CUSTOM-10
Old 05-09-2002, 09:54 PM   #8
Randy70C-10
Post
Hmmm, good question. Start the truck, and put your hand over the exhaust pipe to see if the exhaust is getting good flow. If it's not, then your cat is clogged. I don't know why it would only run bad intermitently though. One thing you could try before spending money is to remove the cat, drive a hole through it with a pipe, and stick it back on. Fire it up and see if it runs any better, if not , at least you didn't lose anything.
Old 05-09-2002, 10:18 PM   #9
ebfabman
Post
A quick check for the exhaust flow is to drill a 3/8 or so hole in front of and behind the cat. If there is a huge pressure difference between the two, the cat is clogging.....
ebfabman is offline   Reply With Quote
Old 05-09-2002, 11:16 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
I am having very similar problems with our 29 S-10 POS blazer. Which 4.3 do you have, the W or the Z? (W is the vortec)
The EGR will seldom set off the check engine light on the Vortec. It is a very crappy design, you can clean it, replace it, but it'll get clogged up real quick with more carbon.
If it is/was running rich, like when it is not fireing on all 6, the verter will get clogged. It also seems more sensitiv than any other catilitic converter i have ever seen.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough?
Columbus Ohio
Old 05-10-2002, 12:08 AM   #11
70shortnphat
"See the U.S.A....."
70shortnphat's Avatar
Post
I beleive this engine is equipt with (ESC)and it can malfunction and not send a code.
The ECM controls timing through the ESC module , knock sensor, and refrence signal from dist. There may be a problem somewhere in this system that is causing the ECM to retard the timing (up to 20 degres) and that is causing a rich condition and heating up the cat. I feel that the chery red cat is the result of another problem and not the problem itself. It will be a problem if It keeps getting red hot and fuel soaked.Good luck with this and please let us know what the problem was when you fix this so we can all benefit.
1970 short bed fleetside
1949 all origional chevy 3600
1974 camaro
Richmond , Texas(just S.W.of Houston)
70shortnphat is offline   Reply With Quote
Old 05-10-2002, 12:23 AM   #12
ddsmith
Glowing since 1978
ddsmith's Avatar
Post
I don't understand why the Check engine light is not on if the condition we are discussing involves a rich mixture. The O2 sensor should pick this up and set the code. I guess this computer stuff is great when it works. I had a MAF go bad on me and no code was set. The car stalled anytime you let RPM go below 2000 RPM. Once I unplugged it the car ran closer to normal. I think it had to do with the problem had to stay in long enough to set the code.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
79 Chevy 4X4 (Tom's old truck)
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 05-10-2002, 07:08 AM   #13
b68gmc
Post
http://www.s-series.com/
Try you post here...
b68gmc is offline   Reply With Quote
Old 05-10-2002, 09:50 AM   #14
texnician01
texnician01's Avatar
Post
I had a problem with my 88 S-10 where it would fall on it's face and try to die when you pulled up to a stop. it would be totally intermittent, unpredictable. I never could figure out what it was. no codes. I finally put a microswitch and light on the egr valve and a light on the control selenoid. It turned out to be the selenoid was not sealing. it would let a vacuum signal get to the egr and would open it and cause a lean condition at idle. can't remember if the 4.3 has this conotrol selenoid but that may be a start. I realize that this problem doesn't explain all of the symptoms you have but it may be a start.
Nathan
1969 C-10 292 I-6 4 spd in the middle of a restoration. going to get a 327 and 3.07 gears but keeping all of the original parts so I can put it back to original later on down the road.
55 chevy 4 door 150
47 Willys CJ-2A
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
05 Harley Night Train
06 1200 Sportster (Wife's bike)
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
texnician01 is offline   Reply With Quote
Old 05-10-2002, 10:25 AM   #15
John Fabris
TOTY 2006
John Fabris's Avatar
Post
Hi,
I have a 93 GMC Jimmy with the 4.3 Vortex motor, and several years ago it starting running rough off and on, and my milages dropped drastically. Took it to several shops to have all of them tell me that they could find nothing wrong. Took it to a good shop and they found that the fuel injection system was faulty. Had that replaced, roughly around $1300.00. BUT, because I had registered myself with GMC as the new owner (2nd owner) of the Jimmy, two months after having the repair done, GMC sent me a recall notice on the fuel injection unit. I sent them the info that I had already had mine replaced and GMC reimbursed the repairs.
Might want to check into that....
John Fabris
john.fabris@autodesk.com
1967 C10 SWB FleetSide Web Page
1971 K5 Blazer 2WD (basket case, but give me two years or so.)
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
